carbotech pad choice
Old Jun 16, 2006 | 06:18 PM
mikegarrison's Avatar
Default carbotech pad choice
I've heard people talk about running XP10s in the front and XP8s in the rear. Any particular reason why? Is it a bias thing or is it just that they had problems with XP8 in the front?
Old Jun 17, 2006 | 06:57 AM
CRDMS1's Avatar
I don't think it has anything to do with bias. The only reason I can think of is expected operating temps. The XP10 has a higher range of allowable operating temps. I'd look up the exact numbers, but I can't get my browser to work properly on the Carbotech site.
Old Jun 17, 2006 | 10:44 AM
boyguan's Avatar
why not the panther + ?
Old Jun 17, 2006 | 12:19 PM
Lower temperature pad. Works fine for beginners; that's what I used for a long time.
Old Jun 17, 2006 | 02:21 PM
CRDMS1's Avatar
Straight from the Carbotech website:
XP10 (F=$158, R=$119)
- Max operating temp -> 1600F (no low range listed)
- Coefficient of friction -> well above 0.6 (their words)
XP8 (F=$147, R=$109)
- Operating temp range -> 250F to 1350F
- Coefficient of friction -> 0.58 to 0.6
So...it could be bias related I guess. XP8 rear set is only $10 cheaper than XP10, but may be more effective in a lower operating range.
Old Jun 19, 2006 | 07:48 AM
TubeDriver's Avatar
I have used XP10/XP8s. The XP10 is just overkill in the rear. The pads will work best in their ideal temp range and the 10s in front and 8 in back get pretty close to that. If you put 10 in back, they will not get as hot as the 10s in front so the 8 in the rear work better. Also, the frict. coeff. is pretty high on the 10s so in the rear it can cause premature lockup.
Old Jun 19, 2006 | 08:06 AM
Thanks. This last set I've been running 8s/8s. Seemed to be working fine. I do have front brake ducting, and I think my fronts run about the same as the rears in temp. I guess I need to use some thermal paint and find out for sure.
Old Jun 19, 2006 | 08:16 AM
Ek9's Avatar
Ek9
Banned
Carbotech recommends a lesser pad in the back (to me anyway) so, there's no hint of the rear locking before the front. I believe they recommended XP10 F and Panther+ in the rear. I had no problems with that and no rear lockup issues even under braking heavy enough for the rear to get squirly.
Old Jun 19, 2006 | 08:23 AM
Well I have ABS in my car, so I'm not too worried about that. If I had a race car with no ABS, it would be a different story.
Old Jun 19, 2006 | 09:50 AM
loudes13's Avatar
+1
panther plus work fine for guys starting out or if you run street tires.
I love the carbotech's, work great, and I can live with the dust (hawk dust eats through wheels)
