Comptech bar+autox=understeer
Originally Posted by RyanAP2inKY,Jun 20 2007, 01:06 PM
So what is going to happen when I put these tires on since I have the stiffer front sway bar is the car going to oversteer b/c of the lower stagger or will the sway bar and rear toe help to calm this down?
-Dave
Ryan,
When I had the FSB, I was running 225/245 RA1's. So with reduced stagger on the not so sticky R-compounds, that 2nd stiffest setting was a slightly understeer biased and kept the inside rear wheel down. You're setup and probably driving preference is going to be a little different, so you'll have to figure out what the best configuration is going to be. But since you're just starting, as the guys above mentioned, don't forget about working on driving technique.
But the basics, stiffer front swaybar equals more understeer. Of course there is going to be a bunch of understeer if you put a big stiffness increase on the balanced stock car. Definitely want to use the big FSB with a reduced stagger setup. Why do this? The wider front tires give more braking and quicker initial turn in. FYI, one of the reasons for the "crazy" stiff FSB is due to the SCCA autocross stock class rules which only allow for FSB modification. If there were no restrictions, people wouldn't necessarily go this route to modify the suspension.
Glad you got the shipment before your event, but I would of assumed that you wanted this for a new tire setup. Oh well, half the fun is screwing around with the car setup anyways
Thanks Fongu so I should be ok with the reduced stagger with the FSB. I'll probably turn down the stiffness on the bar a couple settings since I will probably be creating more understeer from the FSB than oversteer from the lower stagger, and then just play around with the setting on the bar from there.
Originally Posted by RyanAP2inKY,Jun 20 2007, 01:17 AM
I've autox'd my car twice now the first time was fun learned alot. After that event I went and had an alinement done and installed the comptech front sway bar and at my second event I was understeering like crazy.
Don't make the same mistake a lot of people do by spending money before you learn to drive. Been there, done that, got the T-Shirt.
I've been autocrossing for a few years, but I just recently started autocrossing my s2k, and I'm trying my hardest to not spend any money til I learn to drive this car. The only thing I did was an alignment. Tires and bars will come later. No sense in spending money on tires if I'm just going to kill them.
I have to agree with what others have said though, the combination of the front bar along with your rear toe is not helping you at all.
Originally Posted by E-Z,Jun 21 2007, 06:16 AM
You say that was the second time you autocrossed your car. Now does that mean 2nd time autocrossing? Or 2nd time autocrossing your s2k?
Originally Posted by RyanAP2inKY,Jun 21 2007, 09:31 AM
it was only my second time autocrossing in the car, i've been doing it for 3 years and in 4 different cars so I have the experience just now in the car or rwd. so should I keep the rear toe in if im going to be running those new tires or should I go ahead nd set it back to 0?
Originally Posted by sirbunz,Jun 21 2007, 04:55 PM
Seat time FTW!
And how about you share your experiences here for other beginner AS S2K drivers like myself.
sirbunz- What wheels do you have for your car? I can't really tell in your pic. What tires? What tire pressures do you usually end up with? Right now I'm running the stock tires, but I'll probably end up with some 710's for next season after I have a few more events under my belt with this car. I'm the only s2k driver in my region, so I'm just learning the car as I go.
Any advice you can share is welcome.
There's nothing wrong with your rear toe - I run .25" total toe-in with no problems. The rear camber is a bit light, which could cause some oversteer, not understeer.
I've been autocrossing since 1974 (old fart). My setup last year with RE01Rs (205f/225r-16 - about .8" stagger) was -1.5deg. front camber, 0 toe, 5.x deg. caster, Comptech bar on full stiff. Rear was -2.0 camber, 1/8" total toe in. Pressures were 36f/32r. The only times I understeered was when I made it do so. The car was neutral to slightly loose (I shoulda used a bit more rear toe-in).
Seat time, practicing corner entry (if it understeers, you're doing it wrong). Tire pressures may be playing into it as well exact stagger but most of it is driver input...
