Comptech Front sway bar question
I now run the Comptech bar full stiff everywhere. On the street you'll only notice a little push when it's wet. It's a 20 minute adjustment job, so I just leave it. On the street I run a 215/45/17F & 255/40/17R so that should give me even more understeer (40mm stagger vs. stock 20<I know it's really 40>). It feels fine, I just can't throw the back out around 90* corners and scare my girlfriend anymore.
I wouldn't be concerened at all about "streetability". My car is a heavily used daily driver.
According to Comptech, finite element analysis shows that it makes no difference. I know a lot of people swear by it but I'd like to see someone put it on a stand and measure the difference...
Originally posted by cthree
Stock shocks will handle spring rates as high as 275 in/lbs or there about.
Thanks.
I was planning to get a swift bar, since I'm getting swift sport mach springs. I read that it's only 13% stiffer than stock..? Compared to comptech and the other bars out there, that seems like nothing. You guys think it's worth it or I should get a different bar? Thanks a lot
Racing and Competition Forum Equipment Advice Flowchart:
1. Did you list your intended racing and / or competition use?
If yes, continue to #2.
If no, please do so before proceeding further.
2. Are you using equipment for racing and / or competition?
If yes, continue to #3.
If no, please click here or here.
3. Is most of your racing and / or competition done in a controlled setting such as "track" or "autocross?"
If yes, continue to #4.
If no, please click here.
4. Did you provide your complete current / intended damper / spring / wheel / tire / swaybar setup?
If yes, please continue with your query.
If no, please do so now.
5. Need more information?
If yes, click here or here.
