CR specific alignment info
Old Jan 8, 2008 | 03:18 PM
RadioZero's Avatar
Default CR specific alignment info
helms 2000-2008 service manual arrived today. it does have CR specific info, this makes me happy because i already had the 2000-2006 service manual. so, to me, this was not a waste of $125 for the new issue.
the only difference in alignment specs is the Rear Toe-In, all other specs appear to be the same.
00-03 models 6.0+/- 2mm. (0.24+/-0.08 in.)
04-08 models:
except CR model: 3.6+/- 2mm. (0.14+/-0.08 in.)
CR model: 5.5+/- 2mm. (0.22+/-0.08 in.)
fyi.
Old Jan 8, 2008 | 03:29 PM
slightly2ned's Avatar
Can you post the complete alignment specs for reference? Ty
Old Jan 8, 2008 | 06:50 PM
krazik's Avatar
Administrator
who aligns their car to factory specs that hangs out in here? heh
Interesting that they put the static toe back in. I assume it went to less in the ap2 because of the suspension change. None the less the range of adjustment is the same on all cars. and back to my first question
Old Jan 8, 2008 | 09:37 PM
owenxguo's Avatar
Old Jan 8, 2008 | 10:38 PM
Boofster's Avatar
So rear toe at 0 would still be optimal?
I'm going with this spec after the new setup is in:
Front:
Camber - 2
Caster - 7.5
Toe - 0
Rear:
Camber - 2.5
Toe - 0
Thrust Angle - 0
Old Jan 8, 2008 | 10:47 PM
krazik's Avatar
Administrator
optimal and alignment rarely should be used in the same sentance.
optimal for what track? what tires? what sway bar? surface? wheels?
Old Jan 9, 2008 | 10:22 AM
CosmosMpower's Avatar
You guys are brave running 0 rear toe. I think we have 1/4" total or 1/8" per side.
Old Jan 9, 2008 | 11:53 AM
krazik's Avatar
Administrator
I run just about 0 toe (~1/32 to 1/16th in) I love it.
Old Jan 9, 2008 | 08:14 PM
PedalFaster's Avatar
Comparing rear toe settings is meaningless given the differences in setup (Stock class autocrosser vs. heavily modified road race car) and application (autocross vs. big track).
My read of the factory alignment settings is that the CR's probably more predisposed to tail happiness since the factory spec has more toe-in.
HiRpmVTEC
Mar 11, 2010 08:14 AM
HiRpmVTEC
Mar 3, 2010 12:55 PM
Hakkaboy
Jul 15, 2009 07:57 PM
Saki GT
Feb 19, 2009 09:28 PM
terahertz
May 27, 2008 11:08 AM
