Curb Weight rating
Old Aug 14, 2012 | 07:19 AM
davidc1's Avatar
Default Curb Weight rating
So, I've never had my car weighed, and the class I race in is based purely on power to weight ratio.
Yesterday I had my car dyno'd for the first time. It was a Mustang dyno at Evasive Motorsports and I was impressed with 222hp on a real hot day. 95-100 degrees. I've got an AEM V2 intake, test pipe, and Skunk2 exhaust. I was also real, real happy that my AP1 ECU didn't run lean at WOT, The leanest it ran was about 13.3.
Honda's Curb weight for an 03 is 2864lbs. Is that accurate?
How much adjustment to make for replacing the stock air box with the AEM V2? How much for the test pipe and 42 lb exhaust? And how much does the spare tire weigh? And lastly, I've got heavy 22 lb 18" wheels with 225 and 255 tires, any idea how they compare to the 16" stock wheels?
Thanks everyone. (and yes I know, I can just go weigh it, but haven't done it yet)
Old Aug 14, 2012 | 10:09 AM
blasphemy101's Avatar
I remember reading a magazine that weighed their "project" s2k and it came in a good bit under Honda's estimated curb weight. I don't remember any specifics, though.
Old Aug 14, 2012 | 08:17 PM
robrob's Avatar
My wife's 2006 S2000 weighed 2709 with 5/8 tank of gas and no driver.
Old Aug 15, 2012 | 07:35 AM
c32b's Avatar
Search around a bit, it's been covered extensively.
https://www.s2ki.com/s2000/index.php...&f=11&t=507896
My 07 ap2 weighed approx 2850 with me in it & a full tank.
Saved weight on the following:
Soft top delete & replaced with hardtop
Intake, header, exhaust mods saved some weight
Recaro drivers side seat & lightweight rails
Lightweight battery
My coil overs and wheels are lighter than stock
Added weight on the following:
Wing & splitter (including custom mounts)
Brake ducts
Larger radiator
Oil cooler
Various misc stuff like gauges, catch tank
Lard ass driver
Old Aug 15, 2012 | 08:33 AM
sirbunz's Avatar
Same scales, same day, list of every single mod other than stock, and fluid levels or else
Same with dyno #s ... to many variables, provide as many as possible. Items as insignificant as tire pressures can make a difference.
We have seen to much variation over the years in these threads...
-Marc
Old Aug 15, 2012 | 11:20 AM
Orthonormal's Avatar
2005 model
Gendron front bar (1.25" solid)
Penske 8100 shocks
Alpine head unit
Aluminum camera mount
Kosei K1-TS front wheels (4-5 Lbs lighter than stock) and SSR GT7 rear wheels (3 pounds lighter than stock)
R-comp tires, either 245 all around or 245/275
Probably around 5/8-3/4 tank of gas (don't remember for sure)
SCCA scales, around 2006.
2830 Lbs.
Old Jan 1, 2014 | 04:46 AM
J Schmidt's Avatar
Is this a stock s2k? That's the lowest weight I've seen for a 06 (my my)
Old Jan 1, 2014 | 10:55 AM
davidc1's Avatar
yeah, that seems low. My car was 28 30. That was for an 03 replacing the stock air box with an AEM v2 replacing the exhaust with a skunk 2, no spare tire and no tools. And half tank of gas. on a truck scale.
Old Jan 1, 2014 | 05:45 PM
josh7owens's Avatar
My STR car weights 2600
Old Jan 7, 2014 | 06:13 PM
rrthorne8's Avatar
I had a P.I.G of an s2000 on the scales the other day... race weight in B-Stock without driver was 2880 with half tank. 08 i believe.
For reference my 08 in BSP trim weighs 2540 with half tank of fuel on the same scales. Our scales seem to read about 25 pounds low compared to scales at nationals fora 3000 pound car.
