DC PRO Solo!
Originally Posted by Forcednduckshn,Jun 22 2010, 10:15 AM
MAJOR elevation change from the start to the top of hill (at the top of the map.) Does someone know the exact elevation change? I'm terrible with estimating, but I would guestimate a 50-100FT elevation change from the bottom (start) to the top (after the long run up the hill to make either the sharp left or sharp right in to the plateaued slaloms)
I can vouch that the S2000 is worthless on low grip asphalt matched with low speeds and tight corners against the Solstice or Vette and same driver. At least on sandy/loose surfaces everyone is in the same boat. I would rather drive something or somewhere else when in that situation. In low grip and tight situations, the car never gets in to the meat of the powerband. Since the S2000 is usually setup for stability in the powerband, it tends to get pushy while out of v-tec and requiring drastic adjustments to correct. Downshifting further upsets the car, but usually shaves time while making your job much more difficult. Downshifting is usually what I resort to. I'm disappointed to hear of the course design Nick. I would guess that the tight turns followed by straights is what killed the S as opposed to the start. Sounds like you guys were between gears.
Just my .02 and definitely not an exact science as I'm sure there are many opposing examples.
-Marc
-Marc
Sloped lots are just part of the game. Although in general, you get to go back down the hill after you go up the hill, so it kind of balances out. When I saw the relative times between the classes, and how the cars were stratified in B Stock, my first guess was that the course had a lot of slow turns followed by medium length straights, and a lot of sweepers, and not much in the way of slaloms.
FWIW Eric had some very fast times that were dirty on Saturday morning. If the incident hadn't happened and Eric could have driven the rest of the weekend I honestly think he could have been in the hunt for the win. I could be wrong but he would have been in the trophies if he wasn't carrying a cone on both his right side runs. Just my $0.02.
-Marc
-Marc
s2000 x
Jun 2, 2006 05:59 AM
