decision on wheel offset
Old Jun 6, 2020 | 08:53 AM
oaklandfd3s's Avatar
Default decision on wheel offset
I am trying to figure out which wheel offset would be advantageous for track use. I am looking at the TC105X in either 17x9+49, or 17x9.5+45. Small difference but I can't figure out which would be the better choice using 255 tires all around, and possible BBK in the future.
Old Jun 6, 2020 | 02:19 PM
ncrx's Avatar
1. depends on if you're the im ok with rolling/pulling/tab relocation of fenders or not kind of person and are overfenders in your future
2. do you have a ruleset you have to build for
3. which bbk, they all fit slightly different
Old Jun 6, 2020 | 07:39 PM
1. yea I have had all my fenders modified professionally.
2. no rules just regular track days
3. ap racing
I guess my question is more about does the 9 or 9.5 width make a difference on a 255 tire
Old Jun 6, 2020 | 07:49 PM
Hondahero10's Avatar
If you are okay with rolling your fenders and relocating the rear tab you should go with the 9.5" +45. You will also need to run -2.5 ish degrees of camber or more to clear the fenders.
I am running Enkei NT03's which are 17x9.5 +42 in the front and +38 in the rear with -2.5F and -2.7R camber. I also have the fenders rolled with rear tabs relocated. The rears on my setup barely clear the fender so I wouldn't recommend the +38 but +45 should give you plenty of room with 255's. The small amount of stretch with the 9.5" width was a noticeable improvement in steering response for me (I previously ran 17x9 +45 RPF1 with 255). The benefit of 9.5" vs 9" will also depend on your personal preference and which tire model you go with. For example, if you run tires with a soft sidewall, you will be happy you went with the wider wheel.
IMO there is no downside to running the 9.5" wide wheel if it fits.
Old Jun 6, 2020 | 11:54 PM
ncrx's Avatar
run as wide as you can
a 255 is happier on a 10inch rim than a 9.
Old Jun 7, 2020 | 12:57 AM
massiah86's Avatar
I run 17x10 +50 all around with -3.5f and -3r with adjustable upper balljoints. Rolled fenders, tab relocation, cut liners up front. Front has plenty of space for a lower offset or wider wheel. Rear looks to be about the limit, maybe +45 would work. Could go wider with the same offset though. I know someone running 18x10.5" with custom offsets all around & 265 RE-71Rs on rolled fenders - no pulling.
Depends on the tire, too. I was running the A052 and that's 9.75" wide on the 10". Now on AR-1 and it's only 9.5" wide.
Old Jun 7, 2020 | 03:29 PM
thanks for the input guys, I'll go with the 9.5+45
Emil St-Hilaire
Oct 15, 2018 08:48 AM
unclefester
Oct 8, 2018 07:43 AM
Charper732
Oct 7, 2017 09:29 AM
