Differences of Hard top on track
Old Jun 25, 2015 | 12:02 PM
  #21
DavidNJ's Avatar
Originally Posted by vanDiemen
Originally Posted by nissanfanatic' timestamp='1434826189' post='23654714
All I could think is $3k+ down the drain because of a little off...
so in a "little" off you somehow plan on scraping the hardtop/sliding upside down on the pavement?
Even a slow roll on dirt or sand would crush it enough that it wouldn't be repairable...or only repairable at great cost.
Old Jun 25, 2015 | 05:26 PM
  #22
nissanfanatic's Avatar
Yea. That's how it works, right?
Go take a little trip around Sebring and check out some of the tirewalls and wall corners. If you have the balls to enter at 10/10ths with an OEM hardtop and trust you'll never tank slap or spin into any of those then by all means you have 101% of my internet respect. Wouldn't take much of a hit right forward of the rear tire on a concrete wall to completely fawk your hardtop.
I saw way too many things break while on board a ship to think I know it all anymore... The logical answer here for my situation is to remove the $4000 highly resellable body component from my race car, pocket some cash, reinvest the cash into safety items for racing, and replace the hardtop with a cheap replica. YMMV
Old Jun 25, 2015 | 08:23 PM
  #23
Pimpo's Avatar
With the fact that the hardtop itself is 20-30% of the total value of some of our cars, if you don't have to be THAT competitive, forget the hardtop or get a cheaper replica if you really have to.
Old Aug 14, 2015 | 06:32 AM
  #24
vanDiemen's Avatar
Sebring is a poor excuse of a "street" course, don't ever go on there... All the unnecessary bumps from the crappy old pavement would just send you into walls, but aside from that track, I don't think the guy should worry about the hard top if he's planning tank slappers, the frame will be the higher cost damage. And I was assuming replica, who in their right mind 1 buys something that's 30% of the cars value, 2 tries to race with it.
Old Aug 14, 2015 | 10:07 AM
  #25
slowd16's Avatar
Have you ever actually driven Sebring? It's really not as bumpy as you make it sound.
Old Aug 14, 2015 | 10:10 AM
  #26
ViperASR's Avatar
You're right, I tracked Sebring in my s2000, with an OEM hard top. Now I need a new frame, and I lost "2 tries to race with it"
Old Aug 14, 2015 | 10:32 AM
  #27
Ricky_Flowers_'s Avatar
So, so much dumb in one post.
Sebring is a fantastic track with two, maybe three "bumpy" sections. It is considered to be one of the premier tracks in the country. You clearly either haven't driven it, or you're a poor driver, because I've never heard anyone say they didn't like Sebring.
In regards to the hardtop, a lot of people drive their cars on the street (IE: OP) and would benefit from the added comfort a real OEM top provides, whilst also benefitting from the aerodynamic and safety properties created by running a hardtop on track. If you have the means, and if you track your car frequently, an OEM hardtop is the common sense choice. Clearly, you lack common sense.
Thank you for playing.
Old Aug 14, 2015 | 10:57 AM
  #28
pmptx's Avatar
Originally Posted by bgoetz
So I am debating buying a hard top, but am just trying to decide if it is worth taking the plunge and dropping that kinda $. I can get a bunch of seat time for the cost of one. For those who have had both soft top and hard top on track how big of an "upgrade" is one? Also is there any OEM style hard tops that will meet OEM for NASA and are of decent quality?
I am still pretty conflicted as I love the top down on the streets, on the track it is a bit distracting.
By way of personal experience running top up vs down.
On the straight at Road Atlanta I would have to modulate the throttle through 9 and ended up around 115 before the back end got light.
Top up I could go full throttle all the way down and ended up around 125 before the back end got light.
SO for track a hardtop will improve upon the soft top up results, and certainly improve on top down.
Old Aug 14, 2015 | 12:12 PM
  #29
DavidNJ's Avatar
Have you tried any additional aero...rear spoiler, rear wing, front spliter...to add stability at speed? I haven't driven Road Atlanta (I did watch Espinosa's Spec E30 video!) but the idea of sailing into 10a/10b at 125+ with the tail light enough to cause the driver to lift for 9 doesn't seem very confidence inspiring. In this video a 2015 C7 Z06 takes 9 just under 150 at full throttle: https://www.youtube....h?v=VmrPPBrZZ7c
Old Aug 14, 2015 | 10:03 PM
  #30
skatebrian624's Avatar
Originally Posted by djsilverjohnson
I haven't seen any numbers for the S2k, but I know the Miata's typically run a couple seconds a lap faster at Roebling with a hard top. I don't know if the difference is as much with the S2k, but I suspect it is. The guys on here that are doing Time Attack or club racing likely have more info.
I've run Roebling in a cr with hardtop/cr wing and in an ap1 softtop with gt wing. I was faster in the ap1 softtop. There is probably a small aero penalty with the softtop (laminar flow separation), but it's too insignificant to justify the cost of a hardtop. You would be better off using the $3k on either seat time, 2 sets of hoosiers, coilovers, or aero parts.
Originally Posted by sheel' timestamp='1435056120' post='23657109
Most organizations don't allow you to run with a soft-top up - as mentioned some above, it presents a safety hazard in the case of a roll-over. HT will help with aero, but if you're just starting out it's not going to do as much for your time/skills as seat time. If you're debating between the two, my recommendation is to prioritize seat time.
This is exactly where I am at. Actually it is between nothing, roll bar/soft top + a bit less seat time, or hard top only with even less seat time. Regardless of the sharp pokey things I have to think the roll bar/soft top is a FAR safer option. The thing with the top is that it helps keep your arms in the car in the event of a roll over, which is why PCA requires the top up.
I am just not sure I am ready to hack up my car for the roll bar.
Get a rollbar (or better yet, a cage), bucket seat, 6-point harness, and a hans. Your safety on track can't be overlooked. A man just died at Road Atlanta from a high speed crash, and he only had the oem seat and 3-point seat belt. After your safety stuff is squared away, get as much seat time as possible. I promise you the seat time will make you way more faster than a hard top will.
