disable airbag for track
Old Sep 9, 2010 | 11:59 AM
hondaf1's Avatar
Default disable airbag for track
i search for awhile and didn't find anything i was looking for.
i would like to keep to SRS on when i'm driving to the track with the oem seat belt on. then turn SRS off when i get to the track and use the 6 point harness.
is it as easy as removing a fuse or is there more to it? i also read somewhere that the airbag will not go off if the oem seat belt is not fasten. is this true?
Old Sep 12, 2010 | 07:41 PM
JawKnee's Avatar
Not sure if this is what you're look for, but I installed a air bag switch (on the passenger side) several years ago in my '05: http://www.airbagonoff.com/
It was around $140 or so, and I did the installation myself in about 20-30 minutes.
I'm sure you could wire it up for the driver's side.
Old Sep 12, 2010 | 08:37 PM
PedalFaster's Avatar
I can't expect that it is since one of the original purposes of passive restraints was to protect people who didn't buckle up.
Old Sep 12, 2010 | 09:02 PM
hondaf1's Avatar
i would think that's it's probably more dangerous if the airbag activate and you weren't wearing a seatbelt, while your whole body move forward and the airbag come towards your head at supersonic speed. the only issue i see with that is what happens if the one person in front has belts on and the other one doesn't, does the only one air bag activate.
but you are probably right, i just thought i'd verify it.
Old Sep 12, 2010 | 09:04 PM
hondaf1's Avatar
[QUOTE=JawKnee,Sep 12 2010, 07:41 PM] Not sure if this is what you're look for, but I installed a air bag switch (on the passenger side) several years ago in my '05: http://www.airbagonoff.com/
Old Sep 12, 2010 | 11:01 PM
pgss2k's Avatar
Originally Posted by hondaf1,Sep 12 2010, 09:04 PM
i want to disable both driver and passenger side airbag when i'm on track. airbag doesn't do much when using a 5 point harness.
I think perhaps the suggestion was to use 2 of them
Old Sep 13, 2010 | 06:06 AM
bronxbomber252's Avatar
Actually they were designed as a supplement to seatbelts and not as a way to protect those who didn't wear seat belts... hense the name "supplementary" restraint system (SRS)
Old Sep 13, 2010 | 07:00 AM
Actually, passive restraints were originally mandated in order to protect those who didn't fasten their seatbelts. Manufacturers were originally required to provide either motorized seatbelts or airbags. While cars that opted for airbags also included seatbelts, and occupants were encouraged to use them, government standards for airbags did and still do require designing around unbelted occupants.
Reference 1: 1997 article debating whether testing on unbelted occupants should be continued -- see the article called "Hold on unbelted barrier test may be extended" - http://www.iihs.org/externaldata/srdata/docs/sr3209.pdf
Reference 2: New York Times article from earlier this year ("government standards for air bags are intended to maximize protection for unbelted drivers") - http://www.nytimes.com/2010/05/15/bu...15airbags.html
Old Sep 14, 2010 | 08:13 PM
hondaf1's Avatar
did some more searching around the net. not sure if removing the fuse will disable the airbag completely since the a capacitor is used to set off the charge for the airbag. the capacitor will maintain charge even if the power is disconnected. also, it's not as simple as plugging the fuse back in. you have to reset the SRS light. i found a video on how to reset the SRS light on Honda.
got some info from this post
http://www.lotustalk.com/forums/f129/airba...-removal-22413/
[media]http://www.youtube.com/watch?v=PYYzt04o5MU [/media]
Old Sep 17, 2010 | 06:13 PM
Silver9k's Avatar
unplug the harness for the seat belt...that'll disable them
it'll also give you a nice constant "beep beep beep....beep beep beep"
