Disabling ABS?
Gil...not sure about the S2000, but on the NSX, you pull up the e-brake one click, and drive in first gear under 15mph for about 8-10 seconds...and that turns it off. Try this on the S2000 and see if it works...obviously with no one around, which is why it works well on the NSX as you go down pit lane...
-Andie
-Andie
After having driven an S2000 without ABS I don't recommend it, unless you take pleasure in flatspotting tires.
I thought the reason for the NSX handbrake trick was to disable traction control or something, not ABS. I could be wrong.
[QUOTE]Originally posted by jzr
[B]After having driven an S2000 without ABS I don't recommend it, unless you take pleasure in flatspotting tires.
