Extended Lug Studs
Old Sep 30, 2006 | 12:27 PM
Black Nugget's Avatar
Default Extended Lug Studs
I have run into a bit of a dilemna with my build-up and could use some help! Due to the amount of power I was putting down in my S2000 last summer, I did some damage to my axles and have since replaced them. With the fact that my new horsepower goal for the vehicle is substantially high, I have decided to invest in the Inline Pro Differential Conversion Kit. This kit includes new hubs and extended lug studs (along with driveshaft, axles, and bracketry to mount a 300zx diff).
Here is my dilemna - as I have never been too fond of aftermarket wheels I will be mounting a set of AP2 Wheels on my car. As you all might know, the AP2 Wheels are mounted using a ball seat lug nut. With my new extended studs, I will be in need of a ball seat extended lug nut or open end lug nut. To date I have not found such an item and mostly come across conical seat lugs.
Does anyone have a recommendation for my problem?
Thanks,
Chad
Old Sep 30, 2006 | 02:40 PM
davepk's Avatar
Take the OEM lug nuts and cut the top off.
Old Sep 30, 2006 | 04:06 PM
MikeC's Avatar
I bought a set of open ended, ball seat lug nuts from my local Acura dealer for about $28 out the door last summer. I can't recall what model they are from, but any parts guy worth a $hit should be able to find them for you.
Maximum6
Dec 5, 2015 05:56 PM
hypforlife32
Mar 9, 2010 07:58 PM
JspecVtec
Aug 23, 2008 10:15 PM
Spec_Ops2087
Feb 2, 2008 04:46 PM
spider2k
May 26, 2005 10:01 AM
