First Time at the track with AP2 S2000
Old Aug 7, 2006 | 09:19 AM
mts's Avatar
mts
Default First Time at the track with AP2 S2000
I got the S2000 on the track for the first time Saturday. It's a track I've run on several times before with different cars, but the first time with the S2000.
The car is pretty much stock with a hardtop and Avon Tech RA's (225's on the front and 275's on the rear). The car performed beautifully and was a lot of fun.
There were only a couple issues I need to work out. First, the car really seemed to have a big gap in gearing between 3rd & 4th gears. 1-3 didn't seem to have that gap, but it was really tough to keep the car anywhere close to it's powerband in 4th. It may have just been the speeds I was running on that particular track. I'll have to do a search on this.
Second, the car really wanted to come around on me if I got the throttle down too quick in the corners or if I hit even the slightest bump on an off-camber corner. I let a professional driver take it out (never driven an S2000 before) and he spun it on the second lap in an off camber corner. I also had a design engineer from Koni driver and he too talked about how spooky the rear was under certain circumstances. I just got an alignment done so I'll have to do some reasearch on this one as well.
Overall it was a blast. I can't wait to get it out again.
Old Aug 7, 2006 | 12:59 PM
rlaifatt's Avatar
Sounds like an alignment issue as 225 front/275 rear should understeer excessively, not oversteer. Toe should be zero front and 1/4" (as low as 1/8") total toe-in in rear; rear camber -2* or more.
Old Aug 7, 2006 | 01:23 PM
mts's Avatar
mts
I just checked my alignment specs and it sounds like my rear toe may have been a descent size problem. My specs:
Front toe - 1/64 in
Front camber - 1.25
Caster - 6.0
Rear toe - 1/16 in
Rear camber - 1.75
She sees more street time than track time so I was not going for a full track set-up, but it sounds like the rear toe was an issue.
Old Aug 8, 2006 | 09:19 AM
TubeDriver's Avatar
Front toe - 1/64 in
Front camber - 1.25
Caster - 6.0
Rear toe - 1/16 in
Rear camber - 1.75
Add more neg camber at the rear. It won't kill your tires if you run -2.25 to -2.5 in back with a bit of toe in.
AP2 is pretty stable compared to AP1 and with your 225/275 stagger you should NOT have any oversteer problems. What kind of tires pressures were you running?
Old Aug 8, 2006 | 11:09 AM
mts's Avatar
mts
[QUOTE=TubeDriver,Aug 8 2006, 05:19 PM]
Old Aug 8, 2006 | 11:20 AM
TubeDriver's Avatar
Originally Posted by mts,Aug 8 2006, 02:09 PM
I started at 40psi hot on new Avon Tech RA's and moved down to about 35psi hot by the end of the day. I'll have to tinker with that some. I am used to driving lighter cars at the track and I have to adjust lots of my "normal" thinking with a car as heavy as the S2000.
front and rear? Try staggering your pressures with about 5 lbs more in the fronts.
I have not used the Avons but maybe see if low/mid 30s rear and high 30s front works better.
Old Aug 8, 2006 | 01:49 PM
alvanderp's Avatar
Front toe - 1/64 in
Front camber - 1.25
Caster - 6.0
Rear toe - 1/16 in
Rear camber - 1.75
I presume you are saying it has 1/16th of an inch of toe-in in the rear? Hard to tell from your quote.
I run 1/8" toe-out in the front and 1/16" toe in in the rear at -1.9 deg camber all around on my car, and I was just at the track this weekend and it was quite benign on 245/275 V710's. Granted I also have the Comptech front bar. But with less front tire your results should be similar. I would check the tire pressures for sure - I was running 35f/34r psi hot on the V710's and it felt perfect.
Old Aug 8, 2006 | 07:21 PM
RSXLNT's Avatar
More pressure in the fronts reduces oversteer? In my old FWD car, we used to reduce pressure in the back to induce more oversteer - which would be the same thing. I'm sure you're right, I just don't understand. Thanks in advance for any 411.
Old Aug 10, 2006 | 06:33 AM
TubeDriver's Avatar
I think you should reduce your pressures a bit. The rears can have very low pressures without rollover on the tires I use (Hoosier A6, RA-1, and Victoracers) but the fronts do need a bit more in order to keep the sidewall from rolling. You want the lowest pressure possible in the rear (without rollover) probably around ~low/mid 30s HOT and more pressure in front ~high 30s.
Increasing front pressures will often reduce grip and help balance out the oversteer you describe.
trackHERO
Automotive builds
Mar 17, 2016 07:42 AM
turbo pup
22
May 22, 2008 01:49 PM
S2Ken
Sep 9, 2002 08:55 AM
DavidM
Jan 4, 2001 02:45 AM
