Fitting a 10" wheel up front
Old Jan 10, 2016 | 11:54 PM
s2000Junky's Avatar
Originally Posted by 99SH
I've ran 17x10 +62 6ULR wheels (w/spacers) on 275/40 tires w/ASM style fenders.
How is this relevant to the fitment question at all? Your running aftermarket wider fenders, and spacers on a wheel with no disclosure on how big the spacer is, and the wrong size tire. The only thing you have in common to relate fitment is a 10" wide rim. Sorry, dont mean to beat you up, but post like these are just clutter and confusing when helping is the goal. There is a half dozen variables to account for on front fitment, so we need more then one of them.
Old Jan 11, 2016 | 05:23 AM
99SH's Avatar
No you're right, just wanted to bring to light that a tire >255 can fit the fronts if desired.
Old Jan 11, 2016 | 06:59 AM
King Tut's Avatar
My setup is:
17x10 +55 Forgestar F14
255/40/17 Hankook RS3 V2
Ohlins DFVs with 700/600 Hypercos
J's Racing Lower Ball Joints
-3 Deg Camber
Fender rolled flat with slight pull
I think you could get away with no pull though.
Old Jan 11, 2016 | 07:15 AM
yessamgerg's Avatar
Originally Posted by King Tut
My setup is:
-3 Deg Camber
How low are you? These are pretty similar spring rates as what I'm planning for.
The forgestar is an interesting choice, any chance you have a thread about them? I haven't heard of many people using them but the look pretty good. How much do yours weigh
Old Jan 11, 2016 | 07:25 AM
King Tut's Avatar
I am not super low. I have the Ohlins DFVs set to the -15mm they allow in the rear, and have them set at the recommended height in the front currently. There is a whole thread about the Forgestars still on the first page of the R&C forum:
https://www.s2ki.com/s2000/topic/107...0-data-thread/
I did not personally weigh them, but I believe they were weighed by Mod Bargains at 19 lbs.
Old Jan 11, 2016 | 08:33 PM
yessamgerg's Avatar
Originally Posted by The Holy Molar
Good info here as I'm looking to replace my square 17x9 RPF1 setup with a square 949 6UL in 17x10 so I can go a bit wider while clearing the Urge AP Racing BBK I'll be getting. It doesn't sound like there will be much of any issue.
This is exactly my original plan but I think I'm switching to the Evasive Advan RSII. They are very similar in weight but I much prefer the design of the RSII. totally personal opinion though
Old Jan 12, 2016 | 10:30 AM
Mrsideways's Avatar
Running 17x10 949's with +62 and a 275/35 17 with a 2mm spacer (to clear brakes). Fenders are just rolled and not even that much.
Old Jan 12, 2016 | 08:20 PM
Bullwings's Avatar
949 never made 17x10 +62...
They made +72 and +52. The new batch of 17x10 with the new spoke design is being made in 17x10 +52 only.
Are you guys running a 10mm spacer with the old 17x10 +72?
FWIW, I'm able to run the 17x10 +52 with a 255 up front. The rear's fit fine. I can easily fit a 255 in the rear with a standard flat roll and bumper tab relocate.
Up front is a flat roll with a a slight pull. I still have the crease/line in on my front fenders - it's not a full flaring for me.
Old Jan 12, 2016 | 08:22 PM
yessamgerg's Avatar
Thanks for the info, what camber and spring rates if you don't mind my asking. Also is your camber from upper or lower ball joints?
Old Jan 12, 2016 | 09:11 PM
Bullwings's Avatar
Camber is -3.0 all around with a lower ball joint (J's style) - Hard Race/Megan (same manufacturer i'm certain).
I'm on 700 ft lbs Front / 600 ft lbs Rear.
I have about a finger and half gap or so - it's higher up than most S2k challenge cars - I want it to be more streetable and not really have to worry about driveways and what not.
