Flat Electronic oil temp gauge
Old Jul 3, 2016 | 09:44 PM
pmptx's Avatar
Default Flat Electronic oil temp gauge
Goal-Get Oil temp gauge installed without hacking the dash
So the cruise button can be removed and I can connect for the cruise to be be on 100%.
I am looking for a flat electronic gauge so I can simply run the wires through and attach via velcro to the dash.
Ideally would like to keep the dash intact.
I have used my weak google fu and looked at all of the racing equipment sites I could find and nada.
Has anyone seen something like this? I know the AFR electronics are flat with no real depth (so no cutting needed), so that is the example.
Thoughts?
Old Jul 3, 2016 | 10:57 PM
thepoi's Avatar
Look at motorcycle gauges...like this: http://www.ebay.com/itm/Top-Gauge-Di...-/321029121770
Old Jul 3, 2016 | 11:47 PM
pmptx's Avatar
Thanks for the insight. Will do
Old Jul 4, 2016 | 09:04 AM
Driven's Avatar
PLX perhaps?
Their gauges are pretty thin... downside, their customer service is absolutely atrocious, so if you ever have an issue with any of their products you'll be wanting to kick a baby.
But, they work pretty well and look good.
Old Jul 5, 2016 | 05:59 AM
Arro's Avatar
I run PLX gauges, I have an A-pillar dual pod that I've fit over the factory one. The gauge is very shallow (thin), but requires a box for the sensor - I ziptied my box under the dash.
Old Jul 5, 2016 | 07:11 AM
SlowTeg's Avatar
I run a PLX multi gauge in the visor. It's shallow enough to not protrude out the back of the visor (virtually invisible when up).
https://www.s2ki.com/s2000/topic/114...t__p__23851238
Old Jul 5, 2016 | 10:12 AM
Arro's Avatar
Very nice! stealthy....
Old Jul 6, 2016 | 09:19 AM
pmptx's Avatar
Thanks. Will look at the PLX. I am good with putting the box under the dash and just having the gauge fit where the cruise button is located.
All the suggestions are appreciated.
Love the visor mount, very sweet.
Old Jul 6, 2016 | 11:50 AM
Driven's Avatar
The PLX control box can also fit in the stereo area...
I put mine in the fuse box kick panel area, as I had one fail and had to pull it.
That visor mount is very nice! good job on that!
Old Jul 10, 2016 | 06:10 AM
tehlonz's Avatar
A brand by the name of KOSO makes slim temp gauges that could be attached with velcro.
