FP Autocross Setup
So I took the car (2001) out for the first time this weekend at a test n tune in Alabama. It was definitely a learning experience. The car oversteered like crazy. Part of this was me getting use to the car I'm sure, but I also believe the car needs alot of setup work. I am running the KW V3 coilovers (515lb/in F and 515lb/in R). I also was on a 2 year old set of 245/40R17 slicks.
I am very new to all the suspension adjustability. Last year I ran HS in a Honda Accord. The previous owner of the car gave me his alignment and balance specs.
Weight balance is F52% R48%.
Camber -2.5F, -2.0R
Toe -0.86[sup]o[/sup]F(toe-out) -0.52[sup]o[/sup]R(toe-out)
Comptech Front Sway bar full stiff. 178% over stock
Rear sway bar is disconnected
Rebound in the front is 2.5 turns and Rear is about 1 turn.
Not sure about the compression right now.
I am going to Dixie in two weeks and am clueless right now. I am going to order some new A6s and am thinking about ordering some softer spring rates for the rear. I am running Advan RG2 17 x 7.5 +43 and 17 x 8.5 +50. I was thinking about running a 275/40R17 in the rear, but the offset could give me problems. I was also thinking about moving the weight balance more to the rear, maybe 55%.
Any setup suggestions would be great.
Camber -2.5F, -2.0R
Camber -2.5F, -2.0R
Camber -2.5F, -2.0R
The car will be completely different on fresh rubber, but yea, that toe is way out of whack. I run pretty close to zero toe all the way around. With the rear bar disconnected, I definitely wouldn't soften the rear springs any, either.
No, do not get softer springs.
You could either get stiffer springs for the front or, *(recommend)* Get A Saner front sway bar. This bar is Autocross Proven.
It can completely tame the rear end so much, you'd think you were back in your accord.
and I dont agree with the removal of the rear bar.
New A6s have been ordered and are on the way. An alignment will be done by the end of the week. What about the weight bias? Should i bias it more to the rear? I was thinking about 52-55% rear. Its 52%F and 48%R at the moment. The left and right are not neutral balanced, this needs to be done I suppose.
