Front Aero Discussion
Old Sep 30, 2009 | 12:09 PM
MADANT15's Avatar
Default Front Aero Discussion
I am about to buy a high mount APR GT-C 200 and want to discuss options to offset high speed front end lift that will result from the wing. I want to do this on a budget, ideally <$150. I like the APR design, and might try to replicate it, but maybe have it stick out a bit further.
I would probably use something like masonite instead of aluminum though, but retain the metal support rods.
I'm not sure if I want to couple this with a cheap lip, or just mount it on the bottom of the bumper. Any ideas for mounting or other suggestions in general? I want to be able to remove it quickly.
As and alternative idea, I also I am throwing around buying a replica mugen lip and reinforcing it.
Lets start a good discussion!
PS I couldn't find any actually data on front aero, so it would be helpful if anyone has any.
Old Sep 30, 2009 | 12:11 PM
VitaRenovatio's Avatar
You should ask Kel at Evasive to make one for you. The splitter he made for StinkyTofu was absolutely rock solid and beautiful!
Old Sep 30, 2009 | 12:20 PM
toekneeg's Avatar
here you go...
go to your "myS2K" and find my ignore list. I've done that before
Evasive has a replica Mugen lip now for cheap. I'd give that a shot
Old Sep 30, 2009 | 12:27 PM
MADANT15's Avatar
I have all of the tools and know-how to be able to make it myself, I just want to see what approaches other people went for. Especially in regards to mounting points.
Old Sep 30, 2009 | 01:08 PM
Kermdaddy's Avatar
You can PM Mark (MugenRioS2K). He made his out of aluminum. He can stand on it, and he isn't as skinny as I am
Old Sep 30, 2009 | 01:43 PM
Antonov's Avatar
I think they want a few grand for that setup.
Old Sep 30, 2009 | 01:48 PM
Antonov's Avatar
doneliz's car
Old Sep 30, 2009 | 04:42 PM
Kel's Avatar
Kel
Here is the build thread on my splitter for stinkytofu: https://www.s2ki.com/forums/index.php?showtopic=715842
As Antonov mentioned, it is a pricey setup, but only because of the fiberglass work required to make the Amuse bumper fit. A splitter made for an oem bumper would be significantly cheaper.
Old Sep 30, 2009 | 05:08 PM
Originally Posted by toekneeg,Sep 30 2009, 12:20 PM
here you go...
Am I annoying someone?
Old Sep 30, 2009 | 06:31 PM
robrob's Avatar
I made a couple of splitters out of 3/8 plywood. This one I made as big as I thought I could go--it's right at the NASA size limit. I really thought it would drag in the Karussel on Summit's Shenandoah Circuit, but it didn't. It actually works well. I was able to crank in more rear wing since the high speed push is gone. High speed braking is also better. Since I have the points available for TTB I plan to add some vertical end strakes to the outside edge to keep air on the spoiler as it goes around the nose. I'll try a smaller version later. I used to run the APR but it's so small I don't think it did much.
