front camber -2 max?
Old Jul 30, 2009 | 08:23 AM
dan_uk's Avatar
Default front camber -2 max?
Car is lowerred 32mm I wanted -3 camber all round but could only get -2 at the front
The front right wouldha gone higher but the left just won't give up more than -2
When I did the springs I took the upper arms off and pre-loaded the bushings
Old Jul 30, 2009 | 09:00 AM
Antonov's Avatar
front is camber limited. If you want more camber you will either have to run SPC ball joints or J's Racing camber joint.
Old Jul 30, 2009 | 09:10 AM
//steve\\'s Avatar
^and of those I'd go with the j's camber joint
Antonov's Avatar
thats what I've got
Old Jul 30, 2009 | 09:12 AM
dan_uk's Avatar
realy -2 with over an inch drop sounds right? I thought people could get over -2 at stock height - I thought the front had a realy big dynamic camber curve
I'd do a camber kit but I can't afford the +2 points with NASA
Old Jul 30, 2009 | 09:21 AM
Antonov's Avatar
I was never able to get much more than 2 with an inch or so drop, and what i was able to get was in the expense of castor, another reason why camber kits are sweet. I now have 3.2 w/ 8 degrees castor.
Old Jul 30, 2009 | 10:03 AM
//steve\\'s Avatar
I'm lowered down to about a finger gap up front, maybe a hair lower and the max I could get was -2.6 I want to pick up those j's camber joints eventually.
Old Jul 30, 2009 | 11:14 AM
CKit's Avatar
I hate my SPC balljoints. It's very easy to get out of alignment spec if the sliding plate moves a little.
Old Jul 30, 2009 | 11:21 AM
SC_Highlander's Avatar
Spin the top plate 90degrees and lock them into one position.
Old Jul 30, 2009 | 11:37 AM
CKit's Avatar
I'll look into that tonight, thanks for the tip!
