Going to the drag strip tomorrow
Old Apr 15, 2008 | 05:07 PM
RAIN H8R's Avatar
Default Going to the drag strip tomorrow
Im going to the drag strip tomorrow to see what my s2000 can do. This with most likely be the only time I go with the car so dont hate on me too much
I have 245's in the rear with Toyo Proxes T1R's, a comptech SC w/front mount pushing 5.2psi. What kind of 60 foots should I shoot for? This is my first RWD car
Old Apr 15, 2008 | 05:49 PM
icemans2k02's Avatar
shoot for or will you do? if you can get a 2.0 your doing well. 1.4 and they will tow you off the line
Old Apr 15, 2008 | 06:11 PM
RAIN H8R's Avatar
haha, I agree with that Im assuming a 1.6/1.7 is ideal?
Old Apr 15, 2008 | 08:41 PM
Carbon Blue's Avatar
im guessing that you will get a 2.1-2.3. A good launch would be in the 1.8-1.9 range
Old Apr 16, 2008 | 07:34 AM
CosmosMpower's Avatar
You should shoot for 1.9-2.0's with T1R's. Make sure you lower your rear tire pressures, you'll just spin at 32 PSI. I used to cut 1.7-1.8 in my FWD cars on drag radials.
Old Apr 17, 2008 | 05:03 AM
RAIN H8R's Avatar
well. Due to my stock clutch slipping. I could only manage a 2.2 as my lowest. Highest trap speed was 105.5, and my 1/4 was 13.9.
pretty bad i know. But with a clutch and a launch, id be able to hit mid-low 13's all day
Old Apr 17, 2008 | 06:15 AM
Yep, with a 106 trap and a 1.9 60 foot that should get you very close to the 12's.
Old Apr 17, 2008 | 06:37 AM
to the 12s?? no not hardly, i was supercharged with a 1.9 60 foot trapping 108s and the best i could do was a 13.1.
to the op what mods do you have done to your car? and where are you elevation wise?
btw a 2.2 is average with S.
Old Apr 17, 2008 | 07:59 AM
13.1-13.2 is pretty close to 12's. Also 2.2 is pretty bad for a RWD car with LSD, I was pulling 2.2's when I had a 176 whp 1.6L civic with open diff on 195/60/14 H rated factory firestones. Same with a 92 SE-R with LSD tranny and some all seasons.
Old Apr 17, 2008 | 09:10 PM
RAIN H8R's Avatar
you canot compare those fwd cars to an s2k. total different class. But i do agree taht a 2.2 is HORRIBLE.
All i have done is the Comptech kit with the front mount. A removed resonator in the stock exhaust, and NGK BKR6E plugs gapped at .034.
I can hear clicking near the back of my car. Im not to sure where it is comming from, but i need to do some research about it.
