is this a good alignment setup?
Old Sep 9, 2005 | 06:57 AM
jack1122's Avatar
Default is this a good alignment setup?
got a 02' s2k with F. comptech adj. sway bar, 225/50/16F. 245/45/16R. VictorRacer
planning todo alignment today wondering is there a good alignment setup for autox?
Front toe - 0" toe out
Front camber - -1.75 degrees
Rear toe - 1/4" toe in
Rear camber - -2.25 degrees
this is what i plan todo.
Old Sep 9, 2005 | 07:37 AM
PedalFaster's Avatar
https://www.s2ki.com/forums/index.php?showtopic=172595
Old Sep 9, 2005 | 06:39 PM
jack1122's Avatar
i heard honda's cant adj. camber without camber kit.
unless with modification to mounting spot.
so how do ppl in stock class s2k adj. camber?
Old Sep 9, 2005 | 06:52 PM
mikegarrison's Avatar
S2000s can adjust camber, caster, and toe with stock suspension.
Old Sep 10, 2005 | 06:27 AM
jack1122's Avatar
stock suspension without any modification??ie. make bigger hole in mounting spot?
Old Sep 10, 2005 | 08:08 AM
333's Avatar
333
get under the car and look at the lower control arms, lots of adjustments. i might also help you to take a wheel off and get a good understanding about how the suspension works
Old Sep 10, 2005 | 08:11 AM
Yes, without modification. I suggest you buy a Helms manual, or just take off the wheel and look at it. It is adjustable, but not to an unlimited degree.
Old Sep 10, 2005 | 09:34 AM
jack1122's Avatar
thats great. thx alot.
93silvergt
May 27, 2015 02:25 PM
eremoy
Apr 12, 2014 06:27 PM
S2KVITO
Mar 15, 2010 07:07 AM
99SH
Jan 23, 2008 07:46 AM
Dj K-otik
Apr 21, 2004 08:03 PM
