Graph of oil pressure drop during 90mph spin
Finally got to spend a little more time looking (and learning) at the graphs. I stand corrected...oil pressure dropping below 50psi correlates quite well with revs falling well below 5000rpms. This holds true in the spins as well as a few other times where revs dropped (but pressure was never below ~40psi). Pressure drop doesn't seem to correlate with Gs (neither lateral nor acceleration). What I originally took as G-induced "swirling" (with oil pushed to the side of the pan, then to the rear of the pan as I slid backwards under braking) is trumped by the pressure/rpm data.
Here's a oil pressure/RPM graph of the same T1 spin overlayed on the previous lap. Graph shows both T1 and T2 (a 70 mph 180 degree turn) to show the effects of a sustained left.
Blue = spin oil pressure
Red = normal oil pressure
Light Blue = spin revs
Pink = normal revs
Lots of good info with this data acquisition, I just need to learn how to use and interpret it.
Pink = normal revs
Even if the engine was at the center of gravity the deceleration from the tires will overwhelm the centrifugal force that you'd need to get a swirl effect in the oil pan. Now if the car was spinning around the oil pan in space, yes you'd get a swirl and oil would climb all the walls of the oil pan. Add the deceleration from the skidding tires and the swirl effect goes away.
