Gutted Interior Question!
Old Jul 22, 2004 | 12:10 AM
SocratesDTC's Avatar
Default Gutted Interior Question!
I know many of you guys, have gutted S2k's so please reply to this question.
If I gut my interior (like Krazik for example) I will destroy the cars balance (50-50) to 70-30. Then the rear becomes lighter than the front, and I think that I will have some oversteer problems.
Is that true?
Thanks
Old Jul 22, 2004 | 01:34 AM
S2Thizzle's Avatar
I'm sure it throws off the weight distribution a bit, but the no-interior guys make changes to the suspension in order to fine tune the car's balance to their liking.
Old Jul 22, 2004 | 05:16 AM
mxt_77's Avatar
I wouldn't think that it would be a problem. When you gut the interior, all of that weight is between the axles, so it shouldn't throw the balance off too much. Plus, if you're serious enough to gut the interior, you'll be adding a cage which will add some weight back in. And you'll probably also be removing non-essentials like A/C and things under the hood that will remove weight from the front of the car.
Add a functional rear spoiler, have the car corner-weighted... you should be OK.
Old Jul 22, 2004 | 10:20 AM
krazik's Avatar
Administrator
there is no signficant weight movement. You'll end up about 55/45. The car works fine tho.
Old Jul 22, 2004 | 05:31 PM
Scot's Avatar
is that 55/45 with driver? with rollcage? with hardtop?
Just curious.... I forget what my corner weighing was.
My car is down to 2435 or so with no fuel (minimal fuel) with full rollcage, hardtop & a 10lb fire extinguisher.
rai
Sep 17, 2004 04:06 PM
