Hankook RS-3's
Old Aug 1, 2011 | 01:56 PM
MugenAP2's Avatar
Default Hankook RS-3's
The past autocross in Miami by the end of my runs the RS-3's were just way to hot. Luckily there was a puddle which helped out a little. What would you guys recommend on cooling them down between each run?
Old Aug 1, 2011 | 01:59 PM
turbo8765's Avatar
First I've heard of RS3s getting too hot.
rohde88's Avatar
People use a pesticide sprayer filled with ice water
What temperatures were they? Did you use a probe type thermometer?
Old Aug 1, 2011 | 02:21 PM
MugenAP2's Avatar
I did not use a probe, but let me tell you that you can tell when they get hot.
How about this? Fluke 561,IR Thermometer, With Contact Thermometer, To 1022F
http://www.amazon.com/gp/product/B00...SAYJ2GQ99PKAHP
Old Aug 1, 2011 | 02:23 PM
rohde88's Avatar
Originally Posted by rohde88' timestamp='1312235978' post='20836697
[quote name='MugenAP2' timestamp='1312235810' post='20836686']
http://www.amazon.co...7SAYJ2GQ99PKAHP
[/quote]
Infared is generally not as accurate for tires. The carcass cools down VERY quickly, the probe can stick past that. If you have a friend take infared temps that is ok, but if you have to unbuckle yourself, remove helmet, etc. infared is too late to be the most useful.
Fluke brand is "baller" though. Josh
Old Aug 1, 2011 | 02:43 PM
nissanfanatic's Avatar
I definitely wouldn't guess that the tire would get too hot at an autocross...
Old Aug 1, 2011 | 02:45 PM
rohde88's Avatar
we're skeptical. It was hot out and ERSCC has some decent grip at Homestead.
Old Aug 1, 2011 | 03:02 PM
BirdShot's Avatar
On a fast, co-driven car in the summer heat, lot's of RS-3 guys are pretty religious about cooling. Spraying four spots on the ground right before the car is parked and then soaking them thoroughly after the run. I don't run RS-3's so I don't know first hand though...
Old Aug 1, 2011 | 03:07 PM
MugenAP2's Avatar
Well I failed to mention that it was African hot out....
Old Aug 1, 2011 | 03:28 PM
racecar fun's Avatar
^lol
