Hard Dog interior
Old Aug 19, 2012 | 12:15 PM
award78's Avatar
Default Hard Dog interior
Is there any way to install the center console after the hard dog roll bar is bolted down?
Oh yeah its the welded single diagonal.
Old Aug 19, 2012 | 12:43 PM
yonson's Avatar
Depends on which one you have, I have the double diagonal, and I got mine back in, but I had to do quite a bit of modifying to make it work...
Old Aug 19, 2012 | 02:56 PM
rockstar garage's Avatar
with the rockstar bars, the ctr console box is easily put back in with either bar installed..
i am assuming the issue you are having is because you havent installed a bulkhead replacement bar to help support it. you need something in place to keep the ctr box from falling backwards..
PM us, we have our RSG bulkhead replacement bars in stock and ready to ship.
Old Aug 19, 2012 | 04:20 PM
award78's Avatar
I was trying to install with the oem bulkhead in place but I can't get the console past the horizontal bar.
So you can attach the console to this replacement bar?
Old Aug 19, 2012 | 04:49 PM
99SH's Avatar
It'll fit without purchasing any new hardware.
Old Aug 19, 2012 | 05:11 PM
award78's Avatar
I'm guessing I have to unbolt the bar and lift it up to get it in.
Old Aug 19, 2012 | 06:45 PM
99SH's Avatar
If I remember correctly, I installed my bar first then fitted all the plastics. As long as the stock bulkhead is installed, you should have no issue.
Old Aug 19, 2012 | 09:22 PM
If you want to use the stock bulk head, you will have to cut it in half to install reinstall it, or take out the bar and install the bulk head first. Then install the ctr box which bolts to the brace. You will NOT be able to run harnesses with the OEM bulk head installed unless you have the harness bar in the higher position
Old Aug 19, 2012 | 09:27 PM
Our bulk head replacement bar was designed to do what you are trying to do. It installs easily and without having to remove your bar.
Feel free to pm us with any questions. We install these bars on a daily basis
Old Aug 20, 2012 | 05:15 AM
award78's Avatar
my bulkhead's already installed
I should have clarified that I also have the stock roll hoops and garnish installed. I'm just trying to keep as much interiorI can but having problems getting the ctr console in. I might try cutting the front part of the secret compartment box, that's what I'm getting hung up on.
