Hollow vs. Solid FSB
Old Jan 23, 2011 | 09:35 AM
JEEBS's Avatar
Default Hollow vs. Solid FSB
I posted this in the suspension section but I thought I would get a better response here.
I'm looking into purchasing a FSB for my AP2 but ha come across a minor question. I've noticed a few ba out there are hollow like the Eibach and others that are solid like the Saner. I just want to know if I will notice a difference if I got one over the other as far response.
The car is my DD, does see any track days or autox. currently lowered on Espelirs and has a Whiteline Xbrace.
Old Jan 23, 2011 | 09:39 PM
bsyeth's Avatar
If your not driving it on the track or an autoX than why do the mods?
If you want to stop the rear end twitch and snap- you can get a saner and put it on full stiff...it will drive like a front wheel drive car almost.
I have the Saner (solid bar) it is the stiffest as far as I know, and being solid it flexes less. But if the bars are adjustable, then you can make changes to suit what you want.
I would like to hear more about the eibach if anyone is using one.
I got the saner when I was autoXing, but now its a dedicated track car, and Ive lowered the stiffness. If I could get a light weight bar that would perform as well, I would change.
Old Jan 23, 2011 | 10:11 PM
Ben-Salasko's Avatar
Solid is not necessarily stiffer without knowing the ID of both bars and the thickness of the hollow bar you really can't make any judgment.
Old Jan 24, 2011 | 06:10 AM
JEEBS's Avatar
The Eibach is 32mm (Hollow) and the Whiteline is 30mm (solid). I'm leaning more towards the Whiteline since it is solid and has less flex but the Eibach is a tiny bit larger. Will I notice the difference? Both are adjustable.
The reason for the FSB even though it sees no track action is because it will go to 255s all the way around..and reading a few threads w/ non staggered setup with a bigger bar seems to neutralize the twitchiness.
Old Jan 24, 2011 | 06:54 AM
hippo and dog's Avatar
install wise, solid fsb's like saner are difficult to install by yourself, unless you flip the s upside down or have shoulder muscles the size of small pumpkins
Old Jan 24, 2011 | 08:55 AM
miamirice's Avatar
Regarding stiffness there is no diff if the material is the same Stifness is a function of the bars diameter ( r to the 4th power ). The strength should increase with a solid bar but so does the weight.
Old Jan 24, 2011 | 10:44 AM
jyeung528's Avatar
there's a formula, gotta plug in the numbers and calculate it.
can't answer the question as-is
Old Jan 24, 2011 | 01:08 PM
IntegraR0064's Avatar
According to Eibach the stock 04 bar is about 214 lbs/in stiffness. The eibach bar is 368 lbs/in at one setting and 416 at the other setting.
If I do a quick calculation on the whiteline bar I get 375 lbs/in (this is only an approximation from estimates of the size of the bar - if you want a more exact number ask whiteline).
So most likely the whiteline is comparable to the softer setting on the eibach. The eibach is also adjustable, which is nice. The eibach is a little cheaper. Finally, since the eibach is hollow it's probably a little bit lighter.
Personally I'd do the eibach.
Old Jan 24, 2011 | 02:42 PM
JEEBS's Avatar
Awesome! Thanks for a clear and concise response. I was leaning towards the Eibach as well. Hopefully I would need small pumpkins for shoulders to install it. I have about 127k on my endlinks...should I replace them or just make sure there in good order to reuse?
Old Jan 24, 2011 | 08:26 PM
bsyeth's Avatar
I would think the bar should come with new endlinks, especially if its adjustable.
(saner they include adjustable heim joint end links)
I would like to know the weight differences...
FYI Here are the Saner Bar Specs....
1.25" (31.75mm)
3 position adjustable
Soft Setting: 566.0LB/IN (91% Stiffer)
Center Setting: 644.0LB/IN (117% Stiffer)
Stiff Setting: 739.3LB/IN (150% Stiffer)
