Hooosier Tire Pressures
Old May 21, 2002 | 08:02 AM
bsl77s2000's Avatar
Ok, I tried to search for this info but didn't have any luck.......javascript:smilie('')
I need to know the pressures you guys are running with Hoosier AutoX Tires. I have a Comptech adjustable bar and the correct alignments for SOLO II.
Thanks in advance,
Ann
Old May 21, 2002 | 03:55 PM
RandyP's Avatar
Good question, but not specific enough.
What pressures for Hoosiers 225/245?
What pressures for Hoosiers 215/215?
Both are competitive.
For 225/245 i've heard about 46/40 on concrete, less on asphalt.
For 215/215 with max front bar, there is less data.
Old May 22, 2002 | 04:16 AM
bsl77s2000's Avatar
Yes.....so I'll start with 46-40.
Thanks!!!!
Old May 22, 2002 | 06:30 AM
Prolene's Avatar
Thanks!!!!
Those are the pressures with the tires at operating temps (hot), as you probably know. Hoosier manual states to start at 32 lbs cold minimum, but it seems most find starting at 28-26 cold might bring the pressure up to optimum just fine and heat the tire evenly and more quickly than the higher cold pressure.
Old May 22, 2002 | 07:14 PM
robj's Avatar
Ann,
I usually run 45-49 in front depending on the course and surface. Generally adding more pressure to take some of the bite out up front. In the rear I keep it around 42. On warm days, I will usually bleed some air to keep the hot pressures in the ball park of my starting points. This is for 225/245 with a hollow Gendron bar.
Now that you have all my secrets, I really expect you to kick my but at the divisional this weekend. BTW, is Brad co-driving your car this year? Had a lot of fun talking to him at the same event last year.
Old May 23, 2002 | 09:55 AM
bsl77s2000's Avatar
Yeah, Brad is co-driving my car this year Thanks for the info on tires, we've been on Kuhmos all year and StL will be the first event on Hoosiers. Hope it doesn't rain Sunday
Ann
DFWs2k
Nov 4, 2011 07:59 PM
mic_crispy
Feb 6, 2007 08:12 PM
dougie360
Jan 17, 2006 12:53 PM
jbontym
Apr 5, 2004 05:46 PM
Albert
Feb 28, 2003 05:52 AM
