how to fix Flatspots?
Old Feb 9, 2010 | 07:28 AM
dan_uk's Avatar
Default how to fix Flatspots?
I ran auto-x STR without ABS the other weekend and flatspotted my brand new RE-11's :/
I can see patches where the treads lower feel it on the highway ~ like a wheels slightly out of balance.. I checked all the weights are still there
A friend told me what I need to do is put the fronts on the rears and go do a massive burnout to fix it.. that work?
Old Feb 9, 2010 | 08:31 AM
PedalFaster's Avatar
Buy new tires? That's what everyone I know does.
Your friend's approach could theoretically work -- he's basically saying you should remove the same amount of rubber from the rest of the tire as you did from the flat-spotted part. Whether your tires could handle that level of sustained heat without dying is an open question. You could try to accomplish the same thing by shaving your tires, but that would be tough since (a) many tire shaving places won't shave a used tire, and (b) I imagine it would be tough to do a shave that restored a square tire to round.
Old Feb 9, 2010 | 08:33 AM
CKit's Avatar
Why did you run without ABS?
Old Feb 9, 2010 | 09:07 AM
dan_uk's Avatar
where I had to change the rear knuckle it was missing the sensor
didn't realise how much I depend on ABS
Old Feb 9, 2010 | 09:19 AM
bellwilliam's Avatar
I wonder if shaving the tire will work ?
I do know putting it to the rear will lessen the vibration.
Old Feb 9, 2010 | 12:03 PM
CKit's Avatar
Isn't it hard to shave a non-new tire?
Old Feb 9, 2010 | 08:59 PM
nickp's Avatar
burn em down only option not sure how that tire is to shave but you could give it a shot but i would just give em a quick rotation in some water lol just video tape it for us lol gl!
Old Feb 9, 2010 | 11:22 PM
Ludedude's Avatar
Administrator
Most places won't shave a non-new tire.
Old Feb 10, 2010 | 03:48 AM
whitt1's Avatar
In the 60s and 70s some tire stores offered a process called trueing which was similar to shaving but only shaved the high spots. The quality of radial tire back then was so poor that the process was required to make the ride quality bareable. If you can find an old timer with a trueing machine,he could probably help you with your flat spotted tires.
Old Feb 11, 2010 | 12:01 PM
dan_uk's Avatar
well I put the fronts on the rear and when I got in I realy felt the vibration coming from the left rear at low speed
went did some burnouts not very well smoked the clutch but it seemed a bit better after that
its weird the vibration gets less at high speed so I think I will be ok to drive it to the track.. might try and have the wheels re-balanced there if its bad
