how much tread do I need?
Old Sep 9, 2004 | 10:11 AM
stedge's Avatar
Default how much tread do I need?
Just picked up an 03, and for commuting purposes I am going to put on some new tires. However, the original tires have about 13k miles and look pretty worn in the back (no surprise), OK in front. Should I keep these tires around for autocross or first DE (I am a novice and won't be racing), or should I chuck the rears? How much tread do I need in the rear to just play safely on the track, learn a bit. Rather not chunk up new tires...
FYI - for commuting I will likely get some Fuzions or something OK in rain (maybe S03s, but I have them on my other car and they wear fast,a s well, and may be overkill for commuting). I have a second set of wheels from my old S2k and would keep some track tires on those....
Old Sep 9, 2004 | 12:10 PM
jguerdat's Avatar
Minimal tread is fine - slicks have no tread for a reason. Tread is necessary for water but not for dry. As long as they'll last for a useful amount of laps, you would be fine.
Old Sep 9, 2004 | 12:44 PM
stedge's Avatar
thanks!
Old Sep 9, 2004 | 03:13 PM
Ludedude's Avatar
Administrator
Make sure there's no cord showing on the inside edge of the rears and have at it.
Old Sep 9, 2004 | 05:21 PM
drewchie's Avatar
Nearly worn out S02s make great track tires.
Old Sep 10, 2004 | 05:40 AM
stedge's Avatar
Thanks!!!
Old Sep 12, 2004 | 05:40 AM
CoralDoc's Avatar
O.K., I'll disagree
When my OEM tires are nearing the end of their life, I find that they have very poor grip (even under dry conditions) and the cars balance tends even more towards oversteer. For that reason, I would not use nearly worn out OEM SO2 tires on the track.
Old Sep 12, 2004 | 09:06 AM
davepk's Avatar
I agree with CoralDoc,.
Old Sep 12, 2004 | 10:37 AM
ellisnc's Avatar
Originally Posted by CoralDoc,Sep 12 2004, 08:40 AM
O.K., I'll disagree
Old Sep 12, 2004 | 10:56 AM
Ludedude's Avatar
Administrator
All true regarding the OEM tires but in reality they're just fine for a first day track outing.
