Interior for STR?
Old Aug 6, 2012 | 12:12 PM
dan_uk's Avatar
Default Interior for STR?
I have gutted the rear of my car to put in a harddog rollbar, what do I need to put back in the be legal(ish) for STR?
Is the harddog harness bar to put the OEM belts back in legal for STR or do I have to put the stock bulkhead in?
Old Aug 6, 2012 | 12:53 PM
josh7owens's Avatar
Run what ever you want until you start beating people
Old Aug 6, 2012 | 01:57 PM
MattP's Avatar
The answer can be found in the stock rules 13.2.I.1:
Roll bars may be added. Roll bars may be welded in. Standard
rollover hoops and covers may be removed if the resulting instal-
lation meets Appendix C, A. Basic Design Considerations. The
total weight of components added must not be less than that of
components removed.
The only items that may be removed are rollover hoops and covers. The way I read the rule, you'd need the stock bulkhead. That said, I doubt you'd draw any protests unless it was lighter than the stock stuff (and as Josh says, you were winning).
Old Aug 6, 2012 | 03:32 PM
dan_uk's Avatar
So no-one that runs national tours/divisionals/nationals has the harddog with the piece that holds the OEM belts, everyones OEM bulkhead and full plastic?
Old Aug 6, 2012 | 04:05 PM
josh7owens's Avatar
I personally havent seen a car that runs national level STR with a roll bar.
CarBoN
Dec 5, 2010 06:09 PM
chuhsi
Bay Area For Sale
Sep 16, 2010 09:50 AM
S2KMan2000
Sep 22, 2005 02:46 PM
s2k_9000rpm
Aug 19, 2003 09:29 AM
