J's type 1 and 2 gt wing
Old Apr 6, 2010 | 12:25 PM
Antonov's Avatar
Gurneys increase the pressure on the pressure side and decrease the pressure on the low pressure side.
To my understanding, it does so by creating more turbulence near the trailing edge which in turn lowers the boundary layer thickness.
In order to maintain L/D, gurney should be no more than 2% of the chord length.
Hopefully BKL can chime in.
-Dino
Old Apr 6, 2010 | 03:00 PM
darylcha's Avatar
Thanks for clearing up my misconecption Dino!
Old Apr 6, 2010 | 03:41 PM
BKL's Avatar
BKL
Antonov has it right.
A gurney slows down the air ahead of it, increasing the static pressure on the upside of the wing. It also adds a pair of vorticies directly behind the flap which is often associated with a drop in pressure, which in turn maintain flow attachment on the bottom side of the wing.
So a wing can have an even higher angle of attack, or camber, without flow separation when a gurney is installed.
Old Apr 7, 2010 | 12:22 AM
suzukablueS2000's Avatar
^^^^ what if you use a low AOA, is the wing performace (downforce,drag) better with, or without the gurney flap?
thanks
Old Apr 7, 2010 | 12:34 AM
BKL's Avatar
BKL
Even with a low AOA, the wing will produce greater downforce with a gurney. This is because the gurney is still slowing down the air ahead of it which increases the static pressure on the wing's upside.
Old Apr 7, 2010 | 12:42 AM
thanks for the prompt reply
Old Apr 7, 2010 | 12:45 AM
lautll421's Avatar
Will a 1500mm width handle as well as 1600mm?? Any advice appreciated
Old Apr 7, 2010 | 10:36 AM
Antonov's Avatar
less drag, and less downforce, depends on your setup (front aero)
Old Apr 7, 2010 | 03:04 PM
trinydex's Avatar
the visualization
and how it helps
Old Apr 24, 2010 | 04:03 PM
lautll421's Avatar
type 2 is on order now, looking forward for it!!!
D-town-S
Jun 1, 2016 01:07 PM
Dr Jekyll
Jan 19, 2012 10:44 AM
kaansahbaz
Feb 17, 2011 04:05 PM
99SH
Jul 29, 2009 02:27 PM
zSpeedzkwy
May 18, 2008 07:01 PM
