KW V3 Higher spring rates or roll bars?
if "brocken" streets drive is out of your scope - stiffer spring all the way.
if, like me, you do spirited driving on public "brocken" roads this will create problems.
what i eventually works for me is Eibach bars boths on stiff and V3 bump set to 3 (lower adjuster). rebound is not very stiff - only 1-2 clicks stiffer than KW recommends.
this setup is quite good on a road and body roll and directions changes are OK.
with Eibachs on soft and/or bump on 4-5 the body roll was too much for my liking and direction changes were slow.
but onece again - if your only focus is track with more or less smooth surface - stffer springs will make the car much more sharp and "go kart" like.
You're running too low. Billj747 recommends 12.6 front and 13.2 rear as minimum. Hitting the bump stops will cause strange, hard to diagnose handling problems.
You're right, I never thought about it until now but roll center adjusters do lower the car by raising the hub, the lower control arm and shocks aren't affected so you will gain some bump stop relief by installing RCAs.
You can not change angle of lower arm when you have 3 fixed points. Upper arm changes angle.
Only way to change angle of lower arm is through shock length or changing mount points to chassis.
Rob, you are correct, RCA does nothing for shock travel and car will still bottom.
