KW V3s and corner balancing?
Old May 13, 2008 | 09:15 PM
EternalLx's Avatar
Default KW V3s and corner balancing?
Hey guys.. anyone running KW v3s on the street/track that has done cornering balance on them?
Since adjusting height requires putting more or less preload would this have effects on cornering and such? is corner balancing really worth it?
Old May 13, 2008 | 09:38 PM
WindchaserS2K's Avatar
How you suppose to corner balance the KW V3, if you don't mind me asking?
Old May 13, 2008 | 09:46 PM
EternalLx's Avatar
You corner balance the S with the v3s by adjusting the height on all 4 corners untill every corner of the S2K's weight is even or as close as possible.
but the problem with the V3s is that height is adjusted by the amount of preload instead of having a seperate adjustment like some Tein SRC, Ohlins, etc.
Old May 13, 2008 | 10:13 PM
S2Kretard's Avatar
I still want to hear how you "preload" coilovers.
Old May 13, 2008 | 10:18 PM
Billj747's Avatar
Give up, they will never understand...
Old May 14, 2008 | 09:57 AM
krazik's Avatar
Administrator
Old May 14, 2008 | 09:59 AM
krazik's Avatar
Administrator
I preload my shocks at turn-in or is it under braking?
Old May 14, 2008 | 10:01 AM
EternalLx's Avatar
Are you telling me to give up on explaining to him? or are you saying that am not understanding?
Old May 14, 2008 | 10:05 AM
Billj747's Avatar
[QUOTE=krazik,May 14 2008, 09:59 AM] I preload my shocks at turn-in
mikegarrison's Avatar
We are saying that adjusting the perch height is not preloading. (At least, not in any sense that matters. See my later post.)
