Lapping tomorrow, need advice :D
Old Jul 27, 2009 | 10:33 AM
viNz86's Avatar
Thumbs up Lapping tomorrow, need advice :D
searched and nothing came up
Hi All,
I'm going lapping tomorrow and I recently installed some new suspensions. I also got the suspension geometry tweaked as well so the roll center is more or less around the same area. I don't have the specs on me sorry. I'm still learning as we go so bare with me!
Question: What dampening setting do you all recommend?
On my coilovers it can go from:
1 -----------2------------------3--------------->4
(soft)............................................ .........(stiff)
(0% soft)............................................. ..(100% stiff)
I just used numbers for ease of explanation.
Right now I have them as:
Front: Setting 3
Rear: Setting 2
I'm also running a staggered setup.
Any advice on tire pressure as well?
Edit: the track i'm going to is not the smoothest one out there. I want to make sure my suspensions have enough travel through the turns.
Thanks in advance!
Old Jul 27, 2009 | 10:39 AM
wing's Avatar
Start soft and go from there this is going to vary wildly. Or start stiff and work backwards if you end up spinning out a bunch depends how you want to approach it.
Tire pressure will depend on the tire as well.
Old Jul 27, 2009 | 10:51 AM
coldrsx's Avatar
^bingo x 2... start soft then progress. I typically run my PSS9s at full stiff front and about 65-75% of that rear.
Old Jul 27, 2009 | 11:00 AM
viNz86's Avatar
Thanks guys. I will play around with it tomorrow. Lots to think of overnight.
Old Jul 27, 2009 | 11:27 AM
ZDan's Avatar
For tire pressures, I start at ~32front/30rear cold and bleed down to 38psi hot.
Rockweiler
Jun 5, 2015 05:38 PM
Reapur
Jun 11, 2012 08:20 PM
J_D
Oct 16, 2008 11:52 AM
Soon 2 B EVIL
Aug 31, 2004 11:28 AM
Terence
Aug 17, 2004 06:43 PM
