Launch for ap1
The gears are fine. The carrier bearing end caps are the weakest link in the diff, it begins to flex over time from the jolt. As it flexes it pulls the ring and pinion apart and then you snap teeth and bam! The Ap2 diff is substantially more reliable over the long term I have found, it will take more abuse I assume because Honda helped correct the problem by adding thicker end caps over the ap1. Personally Ive blown up two ap1 diffs but still on my Ap2. The end cap upgrade is basically the first level 1 upgrade you can do to the diff. I haven't needed with the ap2 so far, and its got a lot of boosted miles on it. Bellow are some examples of the part modification I mentioned.
http://www.scienceofspeed.com/discon..._differential/
http://www.flatironstuning.com/p-786...l-housing.aspx
http://www.ricks2k.com/products/giftcert.php
Boosted miles are nothing. It's the drag launches on stickies that they can't handle.
Which is why it's important that the OP specifies what conditions and equipment he is using.
Street tires, really not a problem. And your 800-1000 launches are probably not full launches if its the standard turn autocross start. I don't think you've been to that many ProSolos where the launch box is rubbered in concrete...
honda9krpm
May 25, 2005 03:17 PM
