Lightweight pulleys...
Old Aug 25, 2006 | 08:01 AM
stphotographer's Avatar
Originally Posted by Nobody,Aug 24 2006, 11:31 PM
They were the pulleys I bought off of EMC2. I notified him when the first one went....can't remember which pulley it was, but one day I noticed all kinds of powder all over my engine bay. Turned out to be that the bearing loosened up a bit from the pulley it was pressed into and the pulley was grinding up against whatever it was mounted to.
Then recently Asura and I discovered that the idler pulley was basically doing the same thing. Now I need a stock idler pulley washer so I can put my stock one back on. Anyone got one?
I also had the EMC2 pulleys and the same thing happened to me! The pressed bearing failed on my belt tensioner pulley. I've since removed them all except for the water pump pulley which is just a solid piece.
Old Aug 25, 2006 | 10:01 AM
Stratocaster's Avatar
OK, that makes sence. The initial design from EMC2, had a few minor design flaws. First the tentioner pulley was cut in such a way that it only installed backwards. That is will the bearing seat facing the front of the car. So if the bearing loosened up, it could walk off the motor. Second, his initial run had percision bearing and not high speed sealed bearing. That meant the as the bearing ran, it overheated and then it could fail.
Old Aug 25, 2006 | 04:11 PM
Tyraid2K's Avatar
Originally Posted by wildcardtrd,Aug 24 2006, 09:45 AM
throw in proautosports lightweight crank pulley, and you will notice an increase in throttle response, but not as drastic as a lightweight flywheel.
DO NOT DO THIS!!!
Our crank pulley is a harmonic balancer, changing it is like strapping a time bomb to your motor.
Old Aug 26, 2006 | 07:22 AM
wildcardtrd's Avatar
Originally Posted by Tyraid2K,Aug 25 2006, 08:11 PM
DO NOT DO THIS!!!
Do you have proof of this? The Pro autosports guys have been running them on at least 3 of their s2000's that I know of for over 70,000 miles apiece. They are cosistently going over their motors with a fine tooth comb, and have yet to discover any sign of additional wear.
...Most inline engines do not need a harmonic balancer...and the S2000 crank is supported by 5 bearings, on top of being forged...
The Machine
Dec 22, 2019 09:36 PM
hvAlfaWant_S2000
Mar 30, 2015 10:07 AM
suzukablueS2000
Feb 1, 2011 10:13 PM
S2KVITO
Feb 4, 2008 09:37 PM
Initial D God Hand WannaBEE
Feb 21, 2007 06:06 AM
