Mixing Tire Brands?
I have a set of Michelin Pilot Sport Cups, on which I've corded the fronts. The rears still have tread, so I'd like to keep using them. However, I also would like to switch to Toyo RA-1s.
Would it be perfectly safe to run the Toyos on the front and the Michelins on the rear? They're both long treadwear R compound tires.
Originally Posted by Ludedude,Aug 17 2005, 06:35 PM
Doh!
OK, now that the fog has cleared
Get rid of the Michelins (never did like those) and buy four RA1s.
Originally Posted by 124Spider,Aug 17 2005, 03:31 PM
Thanks, J.P. So, in your opinion, I should either buy new Michelin fronts, or replace all four?
when you have all 4 tire the same, you are able to learn them all at the same time. you know when is the tire over heating, enough tracktion..etc.
if you have different tire front and rear, during track time you might have to think more about the differences feeling for front and rear.
not sure if you guys can understand my writing. i'm trying to express my feeling.
not really sure how you killed the fronts first on the cups, but...how about plan Q
run all 4 toyos. when the rear toyos are cooked...swap in the cups since the toyo fronts will be worn as well. theres my 2 turkish lira
