Modified UK Alignment Specs
Old Aug 31, 2018 | 09:06 AM
landapanda's Avatar
Default Modified UK Alignment Specs
Hi everyone. I've been trying to decided on the best specs for my current setup. I've heard great things about the UK spec alignment. I want to max out caster and camber (F: 2.5deg , R: 3deg) and keep the original UK Rear Toe and Front Toe. I track probably 4 times a year and lots of spirited canyon cruises. Do these numbers sounds okay?
Front Caster 6º 45' --> Max
Front Camber -1º --> ~2.5º
Front Total Toe 0º
Rear Camber -2º --> ~3º
Rear Total Toe-in 0º 40'
Old Aug 31, 2018 | 01:51 PM
noodels's Avatar
There are limitations on caster,min camber rear,if lowered on coilovers
Guess rear toe at 0.40 rear its AP1
Old Sep 1, 2018 | 03:00 AM
robrob's Avatar
The UK Specs are for an AP1 and increases the already high factyory .24 inch total rear toe to .286". That's crazy high. I recommend sticking with your stock rear toe-in setting. All the other settings are good with the UK Specs.
RoninS2k
Jun 11, 2011 11:18 AM
tekstar
81
Jun 24, 2009 10:16 PM
teanza
Sep 26, 2008 02:58 PM
02S2Grand
Jun 7, 2008 05:12 PM
pfb
Apr 10, 2002 05:27 PM
