Mounting harness need some help
Old Jan 7, 2013 | 08:56 PM
boyguan's Avatar
Default Mounting harness need some help
I just got my 6 point harness and need some help mourning it
The rears I am wrapping around the bar
I believe I need 2 bendable brackets, two eyelets, and 3 backing plates
I am on the schroth web site and am confused on what I need
They have a few options for bending brackets
Also if I use backing plates with the nut welded do I still need to use washers on the top?
Do I need any other spacers?
Old Jan 8, 2013 | 04:53 AM
robrob's Avatar
You don't need washers when you use backing plates with welded nuts.
I like what Matt used for anchors. They make it easy to clip the clip-on lap belt hardware and leave plenty of room for your seat. You would need 2 per seat:
These are Matt's sub belt eye-bolts. Again you clip the belt hardware to these. You need 2 per seat:
Here's the clip style belt hardware you need. Make sure you get the same size as your belts:
I assume you've seen the how-to but I'll include it for others: http://robrobinette....00Harnesses.htm
Old Jan 8, 2013 | 07:54 AM
slowd16's Avatar
When I put in mine I used 4 of these eye bolts and followed robs site above. These will thread right into the stock belt hole by the door. www.saferacer.com/g-force-eye-bolt-50mm.html?productid=883
Old Jan 8, 2013 | 08:58 AM
boyguan's Avatar
I've read Matt many times
Problem is there are too man to choose. I'm on a stupid I pad so every time I switch pages to copy paste it reloads
For the bendable version. There are two versions
Why use an eyebolt on the driver side when I can use the stock bolt
REVZ TO9
Jun 5, 2007 09:55 PM
bjeong1381
Dec 26, 2006 09:19 PM
revhi
Nov 29, 2006 05:43 AM
roadents2k
Jan 28, 2006 09:28 AM
CIVICTOS2000
Sep 23, 2005 11:46 AM
