My Dyno
Old Dec 17, 2006 | 10:35 AM
rlaifatt's Avatar
Yeah, last year I was running 245F/275R 18's like Ry, but this year 255 17's front and rear per 2006 rules for 2.2 without adding 100 lb ballast. The 255-17 is about the same width as the 245-18 in front, though taller sidewall, but the 275-18 is meaningfully wider than the 255-17 in rear. I was about a second slower this year at Willlow, though faulty since not a head to head comparison. The difference got increasingly worse over the length of a 20-30 min race as the tires lose grip. Time trials wouldn't be as disadvantageous.
Old Dec 17, 2006 | 04:58 PM
gomarlins3's Avatar
That's impressive for a NA car.
Old Dec 17, 2006 | 05:47 PM
krazik's Avatar
Administrator
Its nothing anyone else couldn't do. Of course its not smog legal but most mods kill that.
Old Dec 17, 2006 | 05:57 PM
BlownAP's Avatar
suprising you didnt lose any on the low end with the 3inch.
Old Dec 17, 2006 | 08:38 PM
krazik's Avatar
Administrator
Why would I? Back pressure is an urban myth.
We've already had this arguement here. I went with 3" because my options were 2.5" or 3". had I had the option of 2.75" I would have for weight savings.
Old Dec 18, 2006 | 04:02 PM
S2k-Takara's Avatar
Yeah I think it was me whos was curious about this last time
Hey Ry, what belt did you use to remove the ac?
Other then weight do you feel it made a difference?
Thanks
Randy
Old Dec 18, 2006 | 04:15 PM
StinkyTofu's Avatar
Was this with stock pistons? I always thought you would run into valve clearance with stock pistons and toda c cams? Peak power output isn't as high as you'd expect, but look at that huge midrange gain! Should help quite a bit exiting corners.
Old Dec 18, 2006 | 05:05 PM
krazik's Avatar
Administrator
yes everything else was stock incl pistons. you can see the toda cams dip off them start to make more power at 9300, I think if I had the bottom end to support the rpms there would be more power up top.
and takara. 24.5" 6 rib, some use 24" too but 24.5 keeps the tensioner with its normal range. I'm pretty sure the exact part numbers are listed in a faq in the uth forum
Old Dec 18, 2006 | 05:31 PM
S2k-Takara's Avatar
[QUOTE=krazik,Dec 18 2006, 06:05 PM] yes everything else was stock incl pistons.
Old Dec 18, 2006 | 06:35 PM
krazik's Avatar
Administrator
shit! 45.5 or 45.0 not 24 LOL brain fart.
