Need some really good springs
I can't answer your question. However, there is a lot of information missing from your post:
Why do you "need" a drop?
What do you want to "improve" about your handling? Do you have too much understeer, oversteer, body roll??
It sounds like you have not yet spent the time to figure out what you want (other than looks??). I wouldn't touch the suspension on this car until I did my research first.
a 1" drop isn't gonna improve handling.
Our ride high is just about perfect as far as the suspension geometry goes. .5 - .75" tops. Any more and you're degrading handling.
If you just want to be lower, check out the KG/mm springs.
Ground control and Comptech both sell adjustable perches. You can get any spring rate (with in reason) and lower the car as much or as little (with in a small range) while still having the ability to corner balance with your weight accounted for. The only problem with aftermarket springs is that you cannot adjust the ride height. payneinthe watched me struggle at BW as I 'raised' my ride height so it was ~0.75" lower than stock.
Originally posted by BerlinaS2K
i want the car a little lower but want ot get better all around handling as well. What should i get that is not over 600?
