They look ok. Tons of life. Be sure to rotate. I used to run them around 34-36psi if I remember correctly.
Look good to me, wearing even across the whole section width.
Out of curiosity, what width wheel and tire are these? |
I was running very close to the same setup. Same spring rates on KWs, stiffer front bar, no rear bar, AP2. 0 toe in the front, 1/16" total in the rear. Camber was ~ -2.8 all around. To me, it looks like you're getting a smidge more inside tire wear on the fronts. 0 toe would reduce that. On the rears, it looks like a bit more of tire wear on both edges, so maybe need a bit more tire pressure to get more wear in the middle of the tires. But that's really just eyeballing from photos.
I've been running 38-ish hot but I seem to be having significantly quicker wear than you show there. I predict they will last me about 8hr.
Originally Posted by s2000Junky
(Post 24523718)
Rears look fine. Fronts are taking too much inside wear. I suspect its your toe setting since that 1/16 out becomes 1/8 when rolling with deflection. I usually run 0 to 1/32 in front toe in with poly bushings (less deflection).
I run them at 34 hot. |
Originally Posted by anorexicpoodle
(Post 24523883)
Thanks for the comments. Ran them at ~34 psi hot and felt good.
I tried out 34psi hot yesterday, they seemed to work really well, but these things melt like butter.
