OEM rears on front
Old Sep 27, 2010 | 09:28 PM
LickyMYwalker's Avatar
Default OEM rears on front
hey guys, im lookin to do a budget build non stagger setup so i searched and ive had no definitive answer for this question. im looking to do a oem rears on the fronts but i know ill need a spacer if i dont want to bore it out (ability to rotate). my question is what spacer will i need in the front to make it clear? any other tips on this setup?
Old Sep 27, 2010 | 10:08 PM
PedalFaster's Avatar
You can rotate just fine after you bore them out -- they just won't be hubcentric on the rears.
You'd need a pretty sizable spacer to get the rears on the front, in which case (a) you'd need to shell out a lot of money for longer studs, which would cost way more than just boring out the wheels, and (b) you'd no longer be hubcentric in the front, so you wouldn't really be getting any advantage for your efforts.
Old Sep 27, 2010 | 10:16 PM
oh i mean if i only bored one of them out. dont you only need the spacer to clear the center of the hub to make it fit? lets say like around 5mm?
Old Sep 28, 2010 | 07:15 AM
Zeus2k's Avatar
If you bore out one set then you dont need anything however if you want to be able to rotate the rims front to back then you will need to bore all four out and use a hubcentric ring on the back
I couldnt find anywhere online that had a hubcentric ring that would work so I just got my machinist buddy to make some up. I seem to recall the ring thickness required was around 3mm but I'd get your machinist to take measurements to be sure.
Old Sep 28, 2010 | 07:45 AM
You've lost me somewhere. The reason you open up the centerbore of the wheel is so that it fits around the axle, since stock rear centerbore is 64 mm while the stock front centerbore is 70 mm.
Once you bore out your rear wheels, they'll fit over the front hub without the need for a spacer (for hub clearance -- someone else will have to speak to other clearances). I'm not sure what benefit you'd get from boring out only one of your two rear wheels.
Old Sep 28, 2010 | 08:15 AM
yeah i was just making sure cause when you said bore "them", i thought you were referring to just the two wheels. i understand i need to bore out all 4. im just worried also that they will hit the inside suspension components, some say yes and some say no. theres no real definitive answer to it
Old Sep 28, 2010 | 08:25 AM
scareyourpassenger's Avatar
Ok, I will try to make this simple
The rears stay the same.
You will have to purchase two extra rear wheels and have a machine shop bore the center of the wheels so they fit on the front hubs. Pricing ranges on this from $50 to $120 with some machine shops unwilling to touch them.
Once machined, the rear wheels will bolt up to the front without an issue. and nothing will hit the suspension. If you are lowered and don't add enough camber it will rub the fenders quite a bit.
To make this even easier, I have a set of two rear ap2 2006-2007 wheels bored out I am selling.
Old Sep 28, 2010 | 09:01 AM
there we go thats what im lookin for. how much camber is needed to be ran without it hitting. im at -1.6 now but i guess i could get more since i didnt try to max it yet. bah im lookin for ap2v1 rims...
Old Sep 28, 2010 | 09:13 AM
The amount of camber depends on the ride height.
Old Sep 28, 2010 | 10:36 AM
yeah, im about 13 inches from the middle of the hub to the top of the fender when the car is on the ground.
