Open ECU for IT
Old Jul 31, 2007 | 09:46 AM
crash's Avatar
Default Open ECU for IT
Well they did it.
For next year the s2k in IT can run a aftermarket ecu and change the wiring and sensors.
Improved Touring
Item 1. Effective 1/1/08: Change section 9.1.3.D.1.a.6 and add a new section 7 as follows:
Old rule
6. Fuel injected cars may alter or replace the engine management computer, or ECU, provided that all modifications are done
within the original OEM ECU housing. Only the stock (unmodified) OEM ECU connection to the wiring harness may be used. The
allowance to modify the ECU in no way permits the addition of wiring, sensors, or piggybacked computers outside of the OEM ECU
housing. The stock (unmodified) wiring harness must be used. The installation of a resistor is allowed between the sensor and
the OEM wiring harness. Adjustable fuel pressure regulators are permitted.
New rule
The engine management computer may be altered or replaced. A throttle position sensor and its wiring may be added or
replaced. A MAP sensor and its wiring may be added. Other existing sensors, excluding the stock air metering device, may be
substituted for equivalent units.
7. Wires and connectors in the engine wiring harness may be modified or replaced.
Old Jul 31, 2007 | 10:18 AM
krazik's Avatar
Administrator
you'll still be slow
Old Jul 31, 2007 | 10:22 AM
crash's Avatar
but the car will be faster!!
Old Jul 31, 2007 | 01:30 PM
alejo's Avatar
pita you are
Old Jul 31, 2007 | 02:52 PM
crash's Avatar
Originally Posted by alejo,Jul 31 2007, 01:30 PM
pita you are
His name is Rylan and he is a pita
Old Jul 31, 2007 | 03:07 PM
alejo's Avatar
he's an e-thug though - nice in person
Old Jul 31, 2007 | 03:37 PM
crash's Avatar
thats a good one....
E-thug
Old Jul 31, 2007 | 06:02 PM
krazik's Avatar
Administrator
I'm not an e-thug. I speak my mind and I don't sugar coat. How the **** does that make me a thug?
And James and I have known each other in real life for may years just teasing him. I also wrote "Learn to drive" on his todo list for his car in our shop. So I'm an smart-ass in real life too.
Old Jul 31, 2007 | 06:10 PM
alejo's Avatar
oh don't be sensitive, just took a chance to pick on you
Old Jul 31, 2007 | 06:38 PM
jlucas's Avatar
Actually it's still proposed. If you agree with the change, send in your support .
