Question ~ What are the best shift points
Old May 30, 2002 | 09:29 AM
monkeymaker's Avatar
Default Question ~ What are the best shift points
Has anyone determined the optimum rpms to upshift from gear to gear when trying to maximize speed?
I don't want to assume that it's 9K for each gear until checking with the more experienced track/autoX drivers, so if you wouldn't mind sharing some of your knowledge...
Thanx!
Old May 30, 2002 | 11:23 AM
Sideways's Avatar
Redline it and you won't be disappointed. Shifting at less rpms will ensure you have less power in each gear.
Old May 30, 2002 | 11:26 AM
jguerdat's Avatar
Yep, this has been beaten to death. The torque curves in each gear says it all - there's no crossover of torque falling from a lower gear with the rising torque of the next higher gear so shifting early should be only done if other things are more important (settling for a turn, etc.).
As they say, "Rev to the red!"
Old May 30, 2002 | 11:33 AM
Silver S2000's Avatar
You're goal is to keep the RPMs above 6k so you stay in VTEC. If you go to this cool gear calculator that The Reverand has on his web site: http://reverendsgarage.net/index.php?conte..._calculator.php, you will find that top speed at 8,900 RPMs in 1st gear is 42.8 and 6,000 RPMs in 2nd gear is 44.2 so you need to go to the max (without hitting the rev limiter) to keep close to the 6k VTEC range. 2nd to 3rd has a little overlap (65.6 in 2nd and 61.1 at 6k in 3rd), and 3rd to 4th has more overlap (90.6 to 77.9), so you can shift at lower RPMs in the higher gears.
Hope this helps.
Jack
Old May 30, 2002 | 01:12 PM
The Unabageler's Avatar
you will find a lot of info if you try a search.
Old Jun 2, 2002 | 05:06 PM
Great info. Thanks everyone!
The Boy Wonder
Jan 30, 2007 01:52 AM
Sideways
Jun 16, 2005 06:54 PM
PathNull
Nov 16, 2004 08:28 PM
The Boy Wonder
May 8, 2004 10:59 AM
Squeezer
Apr 10, 2001 01:32 PM
