question on slicks
Old Apr 23, 2004 | 07:04 AM
probert's Avatar
Default question on slicks
i have a chance to get a good deal on slicks but all fours are 245/45/16's. Would it be fine to use this size on all 4 corners?
Old Apr 23, 2004 | 07:27 AM
payneinthe's Avatar
Your tire guy will hate you if you force him to stuff a 245 on a 6.5" rim. Btw, do you know the difference between a slick and a DOT-R?
It can be done, but will require a very stiff bar and fast reflexes. I wouldn't recommend it if it's your first foray into DOT-R tires.
Old Apr 23, 2004 | 08:44 AM
krazik's Avatar
Administrator
What brand slicks are you getting in 16"? And I have never seen a true slick use those sizing numbers, are you sure its not just a DOT tire?
Old Apr 23, 2004 | 12:41 PM
sfphinkterMC's Avatar
probably Michelin?, i saw them on a S2K that crashed at SOW....
Old Apr 23, 2004 | 01:29 PM
kenlola's Avatar
Old Apr 23, 2004 | 01:52 PM
Raymund's Avatar
You'll be fine. That's the beauty of a car with 50/50 weight distribution.
Old Apr 23, 2004 | 02:05 PM
krazik's Avatar
Administrator
wha?
Old Apr 23, 2004 | 03:17 PM
payneinthe's Avatar
Can you explain what weight distribution has to do with tire stagger?
Weight distribution by itself is meaningless until you consider relative roll stiffness. The combination is what determines weight (force) on the tire, and the amount of rubber needed to counteract that force.
Old Apr 23, 2004 | 07:51 PM
PedalFaster's Avatar
If by fine you mean butting into immovable objects backwards, then yes, I agree completely.
Steve
Old Apr 23, 2004 | 07:59 PM
xviper's Avatar
WOW! I hope that none of the advice I give on this forum will possibly get someone KILLED like this last bit of advice (the 50/50 thing) just might.
Aero32
Mar 30, 2011 03:34 PM
edbochung
Jul 10, 2008 11:58 AM
alex s
Sep 23, 2004 11:13 PM
DJHohum
Feb 25, 2002 12:12 PM
Acceleratrix
Jun 5, 2001 10:56 AM
