Question for those who lost ABS
Old Mar 19, 2006 | 10:24 PM
rlaifatt's Avatar
Default Question for those who lost ABS
I know that some of you with stock calipers have lost ABS on track for one reason or another, and locked up tires. Was it front or rear that locked first? (If you spun then that would indicate rear.)
Old Mar 20, 2006 | 06:59 AM
pantyraider's Avatar
It was my fronts that got toasted. Rears look fine to me.
Old Mar 20, 2006 | 07:09 AM
krazik's Avatar
Administrator
all 4 for me at laguna.
Old Mar 20, 2006 | 07:23 AM
l8brakr's Avatar
This would be relative to the pad compounds you may be running, what you are doing while locking up the brakes, your suspension settings and the stagger you have in tire sizes. Theoretically on a stock car the fronts should lock first if travelling in a straight line if that helps you.
Old Mar 20, 2006 | 07:37 AM
rlaifatt's Avatar
In theory, what would be expected to happen to braking characteristics if you have ABS and you increase rear braking relative to front, for example with BBK or stronger race pads in rear only? (Characteristics like stability of car when activated, braking distance etc.)
Old Mar 20, 2006 | 09:16 AM
Ludedude's Avatar
Administrator
I locked/flatspotted all four of my tires last time it happened.
Old Mar 20, 2006 | 10:46 AM
Kobe's Avatar
ask Racing Chris.. he is an expert on driving without ABS.
Old Mar 20, 2006 | 11:32 AM
twohoos's Avatar
Fronts.
Old Mar 20, 2006 | 12:16 PM
rlaifatt's Avatar
To eliminate uncertainty, I have ordered stock rear calipers to go with the stock front calipers .
Old Mar 20, 2006 | 02:26 PM
l8brakr's Avatar
Good call. The possibility of lockup and going backwards off track outweighs any proposed increase in braking efficiency.
