Racepak IQ3 question
Originally Posted by bluesaint,Nov 11 2010, 02:45 AM
Anyone with IQ3 installed can show some installed photos?
Also does the EFI connector works with 06+ ECU to get the readings?
http://www.racepak.com/Components/EFI.php
did you find something appropriate?
i talked with them a couple weeks ago, and they said one is in the works and will be released soon. but i don't think they meant this soon.
Sorry, I thought I had more pictures of mine mounted. We used the mounting holes from the blinkers and wipers to use flat type screws and cut a slit through the center cover to slip it back through. I'll try to get you some more pictures but all you would need is a 1/8" thick backing plate with flat type screws and a hole saw.
S2KANDRE
34
Jan 3, 2005 10:16 PM
