Recommendation for more front camber?
I only track my S2000 and would like more than the stock availability for front camber. I'm overheating and wearing the outsides of my front tires out consistently and some more negative front camber should help.
Is there a product that will stand up to track abuse and offer me a few extra degrees of adjustment?
I suggest steering clear of SPC joints. While many use them without problems, if you strip the nut you can have a complete failure of the ball joint on track. It happened to me. It can have bad consequences.
The J's camber joints are a very solid piece, and I would recommend them for what that's worth.
Hardrace Front Roll Center Adjuster Offset Camber Honda S2000
Can be used with or without the roll center adjuster.
edit: here's a thread on them https://www.s2ki.com/s2000/topic/885...-track-s2000s/
