Recommended Brake Fluid
Old Sep 3, 2004 | 12:24 PM
124Spider's Avatar
Default Recommended Brake Fluid
Hi,
I have some ATE brake fluid on order, but I need to change my pads and fluid before my next track day on the 23rd. If the ATE fluid does not come in time, can someone recommend some high-performance fluid I will be able to buy locally, which will also be appropriate for street driving?
Thanks.
--Mark
Old Sep 3, 2004 | 12:30 PM
mikegarrison's Avatar
Speedware in Redmond will have both ATE and Motul fluid.
Old Sep 3, 2004 | 01:45 PM
TrueDrezzer's Avatar
Castrol 5.1 and Ferodo 5.1
///Robin
Old Sep 3, 2004 | 01:52 PM
124Spider's Avatar
Thanks! I'll go there, since I need to buy a helmet anyway.
Old Sep 3, 2004 | 01:59 PM
PedalFaster's Avatar
Right about now I should throw in my obligatory don't support Speedware pitch.
Steve
Old Sep 3, 2004 | 02:15 PM
Gloffer's Avatar
You could go to your local Ford dealer and get some Ford Brake Fluid. The dry boiling point is nearly as high as ATE's and the wet boiling point is better. Many high performance drivers have used Ford brake fluid as an alternative to higher priced performance brake fluids for years. I think the last time I got some the Ford brake fluid was ~$5.00/pt
Old Sep 3, 2004 | 02:23 PM
PilotSH's Avatar
I'll second the Ford fluid. I know several ppl who have had good experiences with the Ford Heavy Duty fluid at the track.
Old Sep 3, 2004 | 06:21 PM
Ludedude's Avatar
Administrator
Dry boiling point is pretty much meaningless. The fluid contaminates pretty quickly and the only time it will meet its dry boiling point is when you crack that new bottle open, after that it's all downhill. The only way I'd consider the Ford stuff is if I flushed the entire system after every event; you're better off buying a quality fluid and save money by not having to throw a liter of it away every month.
Here's a comparison chart:
Fluid DRY WET
Ford Heavy Duty DOT 3 550 290
ATE Super Blue Racing 536 392
ATE TYP 200 536 392
Motul Racing 600 585 421
Castrol SRF 590 518
Over 100 Deg in wet boiling point is not something I'll give up.
Old Sep 3, 2004 | 06:58 PM
CoralDoc's Avatar
And also consider one of my favorites, Valvoline SynPower with 502 dry and 343 wet boiling points. It's readily available at many automotive parts supply stores.
Old Sep 3, 2004 | 10:38 PM
rlaifatt's Avatar
You can get Motul 600 Racing Brake Fluid at most bike shops. Best track fluid and good for street too.
