Removing Dynamat
Old Nov 21, 2007 | 01:43 PM
Turn-R-Us's Avatar
Default Removing Dynamat
Now that the car has evolved into a track only vehicle I need to shed the weight.....so how the heck do you get this cr-p off????
Any insight is appreciated!
Old Nov 21, 2007 | 01:44 PM
alejo's Avatar
what are you reffering to? sound deadening (goof off and elbow grease) or the foil tar stuff on the transmission tunnel (fingers)?
Old Nov 21, 2007 | 02:22 PM
JawKnee's Avatar
Dry ice and break out the hammer/chisel.
Old Nov 21, 2007 | 03:05 PM
mikegarrison's Avatar
Yeah, that should work.
Old Nov 22, 2007 | 01:16 AM
Turn-R-Us's Avatar
what a pain in the a--
Dynamat.....foil covered tar....the sound deadening stuff. Man I prob got about 40-50 lbs of this stuff to rip through. Dry ice????what do I do just put the dry ice on the thing???
Old Nov 22, 2007 | 01:02 PM
fodden's Avatar
is there really that much sound deadening in the s2k? 40-50lbs?
Old Nov 22, 2007 | 01:08 PM
He added it. Now he wants to remove it.
Old Nov 22, 2007 | 01:09 PM
The idea is that if you get it cold enough it will become brittle. Have you ever frozen a Snickers bar? Same thing.
Old Nov 22, 2007 | 03:25 PM
Turn-R-Us's Avatar
Thanks for the clarification Mike.
I was almost thinking if I get it hot enought with a heat gun it would peel off.....but the getting it cold idea makes sense also.
Such a regret....spend all the time putting it in....and now spend more time taking it out....
oh well
Old Nov 22, 2007 | 05:14 PM
Slows2k's Avatar
Non chlorinated brake cleaner works well to remove the sticky residue. Dry ice works, but there is no easy way to remove it.
