Removing headlight for intake
Repeat after me. If it doesn't say you can, you can't.
"All air entering the intake tract shall pass through the carburetor or fuel injection air inlet. Air intake source shall be within the confines of the engine compartment or stock location."
"Air cleaner assemblies may be modified, removed or replaced. Velocity stacks, ram air or cowl induction are not permitted unless fitted as original equipment. Air intake source shall be within the confines of the engine compartment or stock location. Air intake hoses, tubes, pipes, resonators, intake mufflers, housings, etc., located ahead of the carburetor/throttle body may be removed or substituted. On cars so equipped, the air metering/measuring device (i.e. air flow meter, air mass meter, MAF) must be operational and shall not be modified."
Yeah, I wasn't reading the rule completely but more referencing the fact that even if you took the headlight out, it wouldn't do you much good since you can't plumb a hose to it anyway.
Thanks all. I was just seeing if I would be able to be cheap. The s2k that I am turning into a track car had a dammaged headlight and it was needed to be replaced. I was going to try and see if I would be able to get a way with just taking it out. But I found some used lights for cheap so I will not be taking it out.
Shawn
Shawn
